NEC gt1150 Axcent III
Hi Everyone
I see AMX has a module for the NEC GT-1150 for the Netlinx. I'm looking for one for an Axcent III. (or will the module work?)
    If it's billed as a NetLinx module, I seriously doubt it will work on the Axcent3. Even if it's 100% Axcent3 code, AMX tends to distribute modules as .tok files, and that alone will keep it from running on an Axcent. There is a better than good change, though, that it was written with NetLinx specific code from the ground up.
  • FrankieFrankie Posts: 71
    look in the back of the users manual. they have the basic commands for power, switching inputs.
    Thanks guys, I have the code for the projector working except the runtime for the Axcent III. (Netlinx lamp runtime is up and running.) I not sure if it's a command issue or buffer issue. I did notice an axi. I wrote the other day did not work because the command was not available with the Axccent III.
