TPD4 "custom frame" Border Style
Does anyone know what the capabilities are of this particular
border in TPD4?
Obviously, being called "custom frame", I am inclined to think
that I can somehow modify it from its default appearance.
I have searched all through TPD4 and the help menus, and I am not
able to find any reference to this at all.
Has anyone utilized this border in a design?
What is the purpose of this border if it cannot be modified.
Thanks.
border in TPD4?
Thanks.
I created all the borders, so I guess it falls to me to explain. The short answer is it does nothing special, I just gave it a confusing name. I named it that because it was actually a frame my wife liked (and purchased) so I found an image of it and ended up making a border out of it.
While on the subject of borders are there some borders that you would like to see in future releases? Are there some you would like to see variations of?
Many times I have had to create graphic images for the buttons, because the exact features that I need, just arent available.
I would like to see some of the existing styles (NEON, FUZZY, ELITE, GLOW,) available in a round shape along with the standard rectangular shape.
Also, the ability to set the border color to TRANSPARENT, and select a border thickness. This would allow the button border to be any graphical background color or image that I want.
I suppose the ultimate border would be a user adjustable shape with drag points to set the parameters.
Thanks.
Just like anything else, TPD4 can also be "hacked" (used very loosely.) You could customize this "custom" frame option by swapping out the system file for it. I've done this swapping with custom sounds for a "Beep" and "Double Beep". You just need to go to:
Program Files/Common Files/AMXShare/G4SupportFiles/__system/graphics/border/ and replace CustomFrame_(b,bl,br,t,tl,tr,l,r).png (bottom, bottom left, bottom right, top, top right, top left, left and right respectively).
Of course, after replacing these files, you will need to do a full panel transfer. I'm not sure if you have to follow the same size (14x14), perhaps joeyjoejo can shed some light on whether or not we have to.
Dare I ask?
- Chip (from Jersey)
Meant the button style (it really goes beyond the border), did not intend to insult anybody in NJ (my excuses if I did).
No insult inferred - I'm just curious what a "Jersey" border is supposed to look like!
A sample page should be attached showing a few samples - Besides the Face and Text colors, You can adjust the Contrast (darkness of the shading) as well as the Depth (area affected by the rounding affect). In addition you can add or remove a frame (simple line around the button) in different colors and a range of widths.
In any case, that's really a common style for web pages as well, but it does go well beyond the actual border. As TPD4 is now, you need to do that type of button with images. I have always used one of the ubiquitous and plentiful button design programs that are out there for such things. Perhaps AMX would consider releasing there own.
I tried out my theory with replacing the graphics on the system folder. It works great. You still have to define the border color though, so I just made my match the background. Also, I used a 14x14 chop of each of the corner, and edges. So just to tell everyone, you can "hack" (again, used loosely) the system and use different graphics. However, you can only use 1 custom frame at this point in time. If anyone has any question - feel free to e-mail me, or post. I can post screenshots if anyone would like.
Thanks.
Still not getting the Jersey reference though. If that's supposed to be a common border in C-tron's TP design software, I'd like to know which one it is...
I guess what I posted earlier is as far as we can get in making sizeable custom borders.
*Very* cool border indeed Jeremiah; wish AMX would add more borders like that (as well as those other buttons you show on your panel) for most of us that are not graphics artists. It would be really nice about having these types of graphics available as border so they can easily be re-sized, etc.
One question though - when you later open a saved touchpanel file on a different PC that does not contain the same modification of the "CustomFrame_(b,bl,br,t,tl,tr,l,r).png" file, will the border still look the same or does it revert back to the default "customframe" graphic?
And even more, if you change those png files again for a different project, and then go to open the older project using the customframe, the newest one will be what is being viewed in TPD4. Basically, what I'm going to do from now on, knowing that this works, is have a directory with several folders containing only my custom frames, then swap the default out when needed. This may seem like a pain in the butt, however think of how much time you will save. Instead of having to go into Fireworks every time you need a new sized "border", you can just swap the files. Of course, you'll have to take the time once to make the slices.
One last thing, if anyone has snooped around in the nearby directories, you'll notice that there's a sound directory. Several weeks ago when I was in Programmer 2 in Tampa, I had Dave switch out the default sounds. A double beep became a ringing phone. Instead of using the panel's sound command and load the custom sound, you can just switch out the actual sound file (DoubleBeep.wav) in the system folder and it'll become the "default" sound. So as we're learning quickly, we can change our defaults in one file overwrite, which is very nice in my opinion.
Anway, I think it's just a matter of time before AMX realizes how much of a time saver all this "hacking" can be, and just throw in these features in the next release of TPD4.
is the ability to size the graphic image to the button.
Also the shading capabilities are awesome.
I dont mind creating custom graphics for a project, but I
dont like to constantly be changing the size because the
panel software cant do it.
