using file_open command
shanem
Hi,
Just wondering if anybody has ever used the file_open command to open files for reading and/or writing? Im trying to use it at the moment to open a web page but not having much success. Has anybody any tips on what to do? I have done this before using different languages and it has always been fairly straightforward. I'm pretty new to this language, maybe there is something I have missed? This is what I have tried:
define_constant
char filePath[50] = 'http://www.******.ie' //file to open
integer ioFlag = 1 //read only
define_variable
slong handle
handle = file_open(filePath,ioFlag) //open the file
Problem is handle returns a -5 which means a disk I/O error.
I was talking to tech support about this and they're not really sure why its not working.
define_constant
define_variable
slong handle
If you want some source code to mull over, say the word. If you can give more of a clue as to what you're doing, that would help...
The file operation commands in NetLinx work with the "Disk On Chip" on the original masters, and the compact flash cards (formatted as a disk) on the NI's and ME-260s...
Cheers,
Shane
