Lg Plasma Discrete Control
paradigmpaul
i have an LG Plasma MU-50PM10
I need to have discrete control of power and input selection
the hand controller does not have these functions to capture in iredit
the manual has discrete hex codes but they are only 2 digits , IRedit needs more info that that, what do i do??
what type of controller will take these 2 digit hex codes
->can i then capture that into iredit?
remotecentral.com does not seem to have any discrete functions for LG plasmas...
not enough wire exists to use serial rs232
what are my options...
thanx in advance
thanx in advance
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=devices&br=lg&dv=television&fc=
Zenith codes also work with LG Plasmas. You will need to have the Pronto Pro application loaded into your PC, which you can get from Philips or remotecentral.com. Just copy the hex codes from the .ccf files into IREdit and you should be able to get all discretes for your plasma.
Sincerely,
Ricardo
That's a great trick that is often forgotten. I worked with IR on two displays before I realized that would work.
Kevin
