Keypad Builder Locks on install
Anyone else install this yet? It locks up on the last file 'AMXICON2.TTF' with 0 seconds left of install..
Kevin D.
  • No problems with the install
    You have some type of font problem.
    Kevin,
    Check out the bottom of this thread and see if it gets you any farther.
    http://www.amxforums.com/showthread.php?t=357
    Others have voiced the same type of concern with other AMX installs freezing when it gets to an AMX font. I've never had a problem but I'm not running any type of font manager program. If you are you may want to try turning it off and see if the install goes through.
    Good luck.
  • mkassalmkassal Posts: 12
    Keypad Builder Install Workaround.
    Try Installing it in a different directory. Had the same problem, I did this after downloading it once more.
    Then It worked aok.
    The only thing that was a bummer, is you cannot print a picture of the keypad out. How can one show clients what they are going to get?
    This functionality is highly needed!
  • I ran a complete WebUpdate the other day, and keypad builder was one of the files it got. Installed fine running through Webupdate.. Go figure..
    Kevin D.
  • vincenvincen Posts: 526
    I think you are supposed to use online tools to get a sample of what you'll do in programmation later http://www.amx.com/keypad and there you can print result :)
    Vince
  • On the keypad Preview / KeypadBuilder products . . .
    What other features would you like to see?
