Help connecting to a NX2200
i have problem with NX2200.
when i turn on it, There is only front LED light on in input, output, status
but i can not connnect with this device by any means (USB, LAN...)
i did not program so i don't how to work
what should i do?
Is there code currently on this processor, and if so, do you want to keep it? Is factory reset and option for you? Have you called into the AMX Tech Support team for suggestions? HARMAN Pro Tech Support at +1 (844) 776-4899
I don't know if you have already resolved this. But you need to use the RS232 port marked program to access the system, you will be able to change the IP etc.
Sry thought we were talking about an NI (see what happens when you are doing five things at one time
