Home AMX Technical Discussion
Touch panel display problem
Hello,
I have a problem with 4 units MXT-1000 touch panels. It seems like some air bubbles (from 1 cm to 3.5cm in diameter) forms between display and touch sensitive panel. As a result, the area where this bubbles exists trigger touch events. The panels were installed about 7 years ago.
Is there any solution to this problem?
  • I'd recommend contacting your local distributor/rep or Tech Support to get it sorted out.
