CMessagePipe - say what?
jjames
Does anyone know what the "CMessagePipe::Max = " is? I've seen this before, and I believe was a warning sign to when a system I had locked up before. Or maybe it locked for for another reason - though I never saw that message again when I fixed some code. Perhaps it's nothing . . . maybe not. I can't find anything on it in TechNotes nor on the forum.
Here's a snipped from my startup in diagnostics, note lines 3,4,5,21 and 31.
Any help is appreciated.
1: 12-02-2005 FRI 10:20:31 ConnectionManager Memory Available = 24913092 <10456>
2: 12-02-2005 FRI 10:20:31 ConnectionManager Memory Available = 24923548 <12128>
3: 12-02-2005 FRI 10:20:28 Unknown (Reader=tInterpreter writer=tDeviceMgr)- CMessagePipe::Max = 100
4: 12-02-2005 FRI 10:20:28 Unknown (Reader=tInterpreter writer=tDeviceMgr)- CMessagePipe::Max = 75
5: 12-02-2005 FRI 10:20:28 Unknown (Reader=tInterpreter writer=tDeviceMgr)- CMessagePipe::Max = 50
6: 12-02-2005 FRI 10:20:25 Interpreter CIpEvent::OffLine 0:5:1
7: 12-02-2005 FRI 10:20:25 Interpreter Exiting TCP Read thread - closing this socket for local port 5
8: 12-02-2005 FRI 10:20:24 Interpreter CIpEvent::OnLine 0:5:1
9: 12-02-2005 FRI 10:20:24 SocketManager Connected Successfully
10: 12-02-2005 FRI 10:20:23 Interpreter CIpEvent::OffLine 0:5:1
11: 12-02-2005 FRI 10:20:23 Interpreter Exiting TCP Read thread - closing this socket for local port 5
12: 12-02-2005 FRI 10:20:22 Interpreter CIpEvent::OnLine 0:5:1
13: 12-02-2005 FRI 10:20:22 SocketManager Connected Successfully
14: 12-02-2005 FRI 10:20:21 ConnectionManager Memory Available = 24935676 <21176>
15: 12-02-2005 FRI 10:20:20 ConnectionManager Memory Available = 24956852 <10304>
16: 12-02-2005 FRI 10:20:19 ConnectionManager Memory Available = 24967156 <38808>
17: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:17:1
18: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:16:1
19: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:15:1
20: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:14:1
21: 12-02-2005 FRI 10:20:18 Unknown (Reader=tCypherConnRx writer=tConnectMgr)- CMessagePipe::Max = 50
22: 12-02-2005 FRI 10:20:18 ConnectionManager Memory Available = 25005964 <10592>
23: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:13:1
24: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:12:1
25: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:11:1
26: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:10:1
27: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:9:1
28: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:8:1
29: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:7:1
30: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:6:1
31: 12-02-2005 FRI 10:20:18 Unknown (Reader=tCypherConnRx writer=tConnectMgr)- CMessagePipe::Max = 25
32: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:5:1
33: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:4:1
34: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:3:1
35: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:2:1
36: 12-02-2005 FRI 10:20:18 Interpreter CIpEvent::OnLine 5001:1:1
The Max: value, near as I can figure, is the number of messages backed up when the notification was generated (it's not really an error until you get the notification that the queue overflowed).
