NI-3000 and NI-700 on same network
dsmith
I have a NI-3000 which controls my home theater with two touch panels, the main is a MVP-8400 and a NXT-CV7, used as a spare touch panel. I also have a NI-700 which I bought only to test code on.
How can I set the NI-700 so that it's not recognized only by my NXT-CV7 touch panel for testing new code?
Both NI's and touch panels will be on the same network.
Thank you, dsmith
Set the two to different system numbers. Or use URL in your panel SYSTEM SETTNGS and tell it what IP to talk to. Covered in the documentation.
Thank you John
