Check numeric characters
Dear All,
I have an amplifier which replies the same string sent to as well as the expected reply. For example:
Sending power on command:
'Z1POW1;'
the reply:
'Z1POW1;Z1POW1;' // the first one up to semicolon is the command as it has been sent while the second the reply
I need to know the power status so I'm using a data_event on "string" section.
But when I need to request the power status, I should send the 'Z1POW?;' command and the reply is:
'Z1POW?;Z1POW1;'
My question is how I can check that the character after the 'Z1POW' is a numeric or a character ? In my case, I don't care about the "?" but the "1".
data_event[dvAMP]
string:
local_var char cString[50]
local_var char oneline_grap[20]
cString = data.text
while (find_string(cString,';',1) )
oneline_grap= remove_string(cString,';',1)
if (find_string(oneline_grap,'Z1POW',1)) //Z1POW?;Z1POW1;
remove_string(oneline_grap,'POW',1)
if ( atoi(oneline_grap) ) // is it a number ?
nPower = atoi(oneline_grap)
send_string 0,"'Power = ', itoa(nPower)"
The above does not work reliable as the atoi(oneline_grap) is zero both for the number '0' as well as for any other non-numeric character.
I know that I can override this with some more piece of code but I also really like to know if there is a way to recognize between zero number and non- numeric character.
George
evaluate the penultimate character in the string
if(find_string(oneline_grap,'Z1POW',1) { if(online_grap[length_string(online_grap) - 1] >= '0' && online_grap[length_string(online_grap) - 1] <= '9' ) { nPower = atoi(oneline_grap) send_string 0,"'Power = ', itoa(nPower)" } }OR if you prefer hex values
if(find_string(oneline_grap,'Z1POW',1) { if(online_grap[length_string(online_grap) - 1] >= $30 && online_grap[length_string(online_grap) - 1] <= $39 ) { nPower = atoi(oneline_grap) send_string 0,"'Power = ', itoa(nPower)" } }As you noticed the ATOI function has the somewhat odd behaviour that both ASCII zero ( '0', $30) and any non-numeric character both give you the result 0. It would have been much easier if any non-numeric character would result in -1. So if zero (0) is a value you are interested in, be careful with ATOI. I usually do something like Ian described, just evaluate the ASCII itself.
