IR port common ground?
Hello all,
Do you know if the NI series of controllers use common ground on the IR ports. So the question is: can I use a 5 core cable for 4 IR emitters? IR1,IR2,IR3,IR4 and ground. That is the only one available right now.
I don't have a controller handy so I could check myself. And I couldn't find the information anywhere.
Thanks in advance!
Mixu
