Parse part of host name from controller
Hi,
Still sorta new to coding so bear with me,
I'm trying to parse part of the hostname from the controller as a variable to use it to define settings for specific rooms later in code. I can get the full hostname by using hostname = ipaddress.hostname, and then from that I only need the last 6 characters. our host names are set up as BLDG-FLOOR-ROOM.xyz.com i just need the 'room' part of the name. i've tried using right_string or remove_string but they all come up as empty values in debug. any thoughts?
I'd do a while through the string removing at the "-".
hostname = ipaddress.hostname amx_log(AMX_ERROR,"'BEFORE hostname = ', hostname"); // Remove 'BLD-' and 'FLOOR-' prefix while(find_string(hostname,'-',1)) { remove_string(hostname,'-',1); } // Remove '.com' suffix if(find_string(hostname,'.com',1)) { set_length_string(hostname, length_string(hostname) - length_string('.com')); } amx_log(AMX_ERROR,"'AFTER hostname = ', hostname");Ian,
Where abouts would you put that in code? I tried calling it as a function, setting up an online event but it still comes up blank in debug.
You mentioned a function - can you write a button event to call the function for testing purposes at runtime?
Question - where are you setting your ipaddress.hostname variable from?
And yes it would best be found in a function
define_function char[255] parseHostName(hostName) { stack_var char tempString[255]; tempString = hostName; amx_log(AMX_ERROR,"'BEFORE = ', hostName"); // Remove 'BLD-' and 'FLOOR-' prefix while(find_string(tempString ,'-',1)) { remove_string(tempString ,'-',1); } // Remove '.com' suffix if(find_string(tempString ,'.com',1)) { set_length_string(tempString , length_string(tempString ) - length_string('.com')); } amx_log(AMX_ERROR,"'AFTER = ', tempString "); return tempString; }I just made a simple program with the example you posted, but its giving an illegal assignment statment at tempstring = hostname.
If i comment that out it will compile.
PROGRAM_NAME='Hostname Program'
(* FILE CREATED ON: 06/04/2020 AT: 09:33:14 )
( FILE_LAST_MODIFIED_ON: 06/04/2020 AT: 10:22:51 )
( System Type : NetLinx )
( REV HISTORY: )
$History: $
( DEVICE NUMBER DEFINITIONS GO BELOW *)
dvMaster = 0:1:0
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
IP_ADDRESS_STRUCT IPAddress
DNS_STRUCT DNSName
CHAR HOSTNAME[50] = 'IPAddress.HOSTNAME'
CHAR SUBNET[50] = 'DNSName.DomainName'
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW )
( EXAMPLE: DEFINE_FUNCTION () )
( EXAMPLE: DEFINE_CALL '' () *)
stack_var char tempString[254];
return tempString;
(* STARTUP CODE GOES BELOW *)
(* THE EVENTS GO BELOW *)
DATA_EVENT [dvMASTER]
ONLINE:
GET_IP_ADDRESS(dvMaster,IPAddress);
GET_DNS_LIST(dvMaster,DNSName);
parseHostName(hostname);
SUBNET = DNSName.DomainName;
HOSTNAME = IPAddress.HOSTNAME;
DEFINE_PROGRAM
My bad - missed the data type for the parameter
parseHostName(char hostName[])
