Random numbers
Dear All,
  1. I need to randomly select 10 numbers from 1-100 and store them in an array. Random_number(101) selects a number in range 0 <= number < 101 but zero must be excluded.
I could make some piece of code to check if the selected number is zero:
for (iNumber= 1 ; iNumber <=10 ; iNumber ++)
iNumberArray[iNumber] = random_number(101);
    while ( iNumberArray[iNumber] == 0 )
  1. I need then to check these 10 numbers to be different for each other. If there are equal numbers, it should re select different ones
  2. Finally I need to short them from the lower to the higher number
Basically, I’d like to ask some help for 2 and 3.
George
  • You could do something like this. I have checked this quickly and it works as expected, but depending on how 'paranoid' you are, it could be worth checking this more thorough.
    DEFINE_CONSTANT
    MAX_NUMBERS = 10
    volatile long lNumberArray[MAX_NUMBERS]
    volatile long lSortedArray[MAX_NUMBERS]
    Functions:
    1 - generate the array
    define_function fnFillArray()
        stack_var volatile integer i
        for (i = 1 ;i <= MAX_NUMBERS ;i ++)
        //set max range 1 lower and add 1 to avoid zero
        lNumberArray[i] = random_number(100) + 1
        set_length_array(lNumberArray, MAX_NUMBERS)
    You can check the array with debug. You can change some array members to be duplicates of others there also, to check the next function.
    2 - check for duplicates
    define_function fnFindDuplicates(long lArray[])
        stack_var volatile integer j
        stack_var volatile integer nDuplicate
        while (TRUE)
        //after replacing a duplicate check again
        //cause it could be another duplicate
        for (i = 1; i <= length_array(lArray); i++)
            for (j = i + 1; j <= length_array(lArray); j++)
            if (lArray[i] == lArray[j])
                send_string 0,"'Duplicate: ',itoa(lArray[i])"
                //re-generate and check array again
                nDuplicate = i
                break
            else
                nDuplicate = FALSE
            if (nDuplicate)
            break
        if (!nDuplicate)
            send_string 0,'Duplicate checking done!'
            return
    3 - Sort the array
    This is a 'standard' insertion sort routine. If you want to know how it works, just Google. Lots of examples.
    define_function long[MAX_NUMBERS] fnSortArray(long lArray[])
        //insertion sort routine
        stack_var volatile long    lValueToInsert
        stack_var volatile integer nHoleposition
        stack_var volatile long    lTempArray[MAX_NUMBERS]
        lTempArray = lArray
        for (i = 2; i <= length_array(lTempArray); i++)
        lValueToInsert = lTempArray[i]
        nHoleposition = i
        while (lValueToInsert < lTempArray[nHoleposition - 1])
            lTempArray[nHoleposition] = lTempArray[nHoleposition - 1]
            nHoleposition --
            if (nHoleposition == 1)
            break
        lTempArray[nHoleposition] = lValueToInsert
        send_string 0,'Sorting done!'
        return lTempArray
    I tested these functions with simple triggers from pulsing channels on a virtual device with 'control a device' and checking the results in 'debug' but there are may ways of doing this.
    vdvStart = 33000:1:0
    channel_event [vdvStart,1]
        ON:
        fnFillArray()
    channel_event [vdvStart,2]
        ON:
        fnFindDuplicates(lNumberArray)
    channel_event [vdvStart,3]
        ON:
        lSortedArray = fnSortArray(lNumberArray)
    Good luck
  • hello richardherman,
     they are all so useful..... I will give a try.... Many thanks for your help and your time !!!
    George
