Random numbers
Dear All,
- I need to randomly select 10 numbers from 1-100 and store them in an array. Random_number(101) selects a number in range 0 <= number < 101 but zero must be excluded.
I could make some piece of code to check if the selected number is zero:
for (iNumber= 1 ; iNumber <=10 ; iNumber ++)
iNumberArray[iNumber] = random_number(101);
while ( iNumberArray[iNumber] == 0 )
I need then to check these 10 numbers to be different for each other. If there are equal numbers, it should re select different ones
Finally I need to short them from the lower to the higher number
Basically, I’d like to ask some help for 2 and 3.
George
You could do something like this. I have checked this quickly and it works as expected, but depending on how 'paranoid' you are, it could be worth checking this more thorough.
Functions:
1 - generate the array
define_function fnFillArray() { stack_var volatile integer i for (i = 1 ;i <= MAX_NUMBERS ;i ++) { //set max range 1 lower and add 1 to avoid zero lNumberArray[i] = random_number(100) + 1 set_length_array(lNumberArray, MAX_NUMBERS) } }You can check the array with debug. You can change some array members to be duplicates of others there also, to check the next function.
2 - check for duplicates
define_function fnFindDuplicates(long lArray[]) { stack_var volatile integer i stack_var volatile integer j stack_var volatile integer nDuplicate while (TRUE) { //after replacing a duplicate check again //cause it could be another duplicate for (i = 1; i <= length_array(lArray); i++) { for (j = i + 1; j <= length_array(lArray); j++) { if (lArray[i] == lArray[j]) { send_string 0,"'Duplicate: ',itoa(lArray[i])" //re-generate and check array again lNumberArray[i] = random_number(100) + 1 nDuplicate = i break } else nDuplicate = FALSE } if (nDuplicate) break } if (!nDuplicate) { send_string 0,'Duplicate checking done!' return } } }3 - Sort the array
This is a 'standard' insertion sort routine. If you want to know how it works, just Google. Lots of examples.
define_function long[MAX_NUMBERS] fnSortArray(long lArray[]) { //insertion sort routine stack_var volatile integer i stack_var volatile long lValueToInsert stack_var volatile integer nHoleposition stack_var volatile long lTempArray[MAX_NUMBERS] lTempArray = lArray for (i = 2; i <= length_array(lTempArray); i++) { lValueToInsert = lTempArray[i] nHoleposition = i while (lValueToInsert < lTempArray[nHoleposition - 1]) { lTempArray[nHoleposition] = lTempArray[nHoleposition - 1] nHoleposition -- if (nHoleposition == 1) { break } } lTempArray[nHoleposition] = lValueToInsert } send_string 0,'Sorting done!' return lTempArray }I tested these functions with simple triggers from pulsing channels on a virtual device with 'control a device' and checking the results in 'debug' but there are may ways of doing this.
DEFINE_DEVICE vdvStart = 33000:1:0 DEFINE_EVENT channel_event [vdvStart,1] { ON: { fnFillArray() } } channel_event [vdvStart,2] { ON: { fnFindDuplicates(lNumberArray) } } channel_event [vdvStart,3] { ON: { lSortedArray = fnSortArray(lNumberArray) } }Good luck
hello richardherman,
George
