Multi-Dimensional Constant Declaration
danportugal
Is this a valid way to declare multi-dimensional array?
DEFINE_DEVICE dvDev01_1 = 2001:1:1 dvDev02_1 = 2002:1:1 dvDev03_1 = 2003:1:1 dvDev04_2 = 2004:1:2 dvDev05_2 = 2005:1:2 dvDev06_2 = 2006:1:2 DEFINE_CONSTANT volatile dev dvDev1[3] = { dvDev01_1, dvDev02_1, dvDev03_1 } volatile dev dvDev2[3] = { dvDev04_2, dvDev05_2, dvDev06_2 } volatile dev dvDevALL[2][] = { dvDev1, dvDev2 }
Two quick things to try before asking: Does it compile, and if so, Does it work as you intend.
It does compile. My current array is big and i can't seem to debug it. Current size is [6][24]. Its for 6 DGX 1600. I want to create levels to track the outputs. 24 because of the additional 8 outputs of the audio card.
When i try to do a create_level at define_start against it. I get errors.
That's why the question on this forum.
Does it have to be an array or could it be dismantled a bit better using Device, Port, System to populate the levels based on the calling device or port numbers?
guess i'll just create level events.
