Monoprice hdx(c)-501e hdmi switcher
mohillic
I could not find an IR file for this device, so I made one. If anyone out there has any interest or need it I am happy to share it with you.
I'll quote John Nagy: https://proforums.harman.com/amx/discussion/125517/ir-files#latest
"The forum isn't suitable as a file repository, and worse as a link repository to a privately hosted file repository. Unless the forum moderators have some better suggestions, I'd encourage you to use and to submit your additions to the already huge and free Global Cache Control Tower IR Database.
https://irdb.globalcache.com/"
This is interesting. The whole reason I'm using AMX now is because iRule (which uses global cache products) got bought out by Kramer and Kramer decided to snuff the whole project (EOL is 2021) I'm replacing all the iRule projects I had built with AMX now. Also I did try the codes I had used for my GC-100-12 but they don't work with the nx-2200 so I had to recreate them using the iredit app.
The codes used in Global Cache products are not "hex codes" which AMX and many others use. The library at CONTROL TOWER shows both formats, the GC ("sendIR") and HEX, for each command. Thusly: Bold is HEX to use in AMX.
"POWER ON","sendir,1:1,1,38000,1,69,346,174,21,21,21,64,21,21,21,21,21,64,21,64,21,21,21,21,21,64,21,21,21,64,21,64,21,21,21,21,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,1537,346,97,21,3674","0000 006D 0022 0002 015A 00AE 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0601 015A 0061 0015 0E5A",,
