Flashplayer is out of date
AXA_Didier
hello… since yesterday Flash player is out of date and for security reasons was blocked to the browser into my office...I no longer know how to open Classic IU in RMS....is there any way around / fix this problem please ?
RMS Enterprise 4.8.0 is available for download on AMX.com:
https://www.amx.com/en-US/products/rms-ent
If you are unable to update your RMS implementation, you can leverage (for a few more months) the Adobe Enterprise Enablement feature. I did a quick search on Adobe Enterprise Enablement - here is a video of a user creating and placing the config file to enable Flash on your device.
https://youtu.be/nOcW1Ugt7Mk?t=96
Did anyone have any luck using the above method to access a DVX switch web interface? I tried this but just got a blank white screen
Another option would be the Flash Player Projector Debugger available on this page: (https://www.adobe.com/support/flashplayer/debug_downloads.html )
Or from this direct download link:
https://fpdownload.macromedia.com/pub/flashplayer/updaters/32/flashplayer_32_sa_debug.exe
The debugger is a standalone flash player that runs without a browser on your computer. If you put the address of your DVX switcher flash file in as the file to open you can still access the switcher setup on the DVX. Enter this in the file open dialog: http:///web/http/dvx_hd.swf
This even works when the DVX is remote, and with hostnames
Note that the direct download link, if clicked as is, results in a 404 not found. You need to remove the closing parenthesis ")" that comes with the link as typed. The same is likely if you copy the file open link to the DVX.
Updated - my apologies
Tried the "Flash Player Projector Debugger"
But getting the following error messages and cant control any DVX Ni or NX units Ive tried:
"An Actionscrict error has occurred"
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.amx.dd.models::AppModel/setValuesFromXML()
at com.amx.dd.controller::LoadSettingsCommand/onPageResults()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()
at mx.rpc::Responder/result()
at mx.rpc::AsyncRequest/acknowledge()
at DirectHTTPMessageResponder/completeHandler()
at flash.net::URLLoader/onComplete()
Surprised this worked for me...
1-Set computers clock back by a year, pre 2021.
2-Opened oldschool Internet Explorer.
3-Opened older DVX (2155) and was able to access the DVX Flash/AV Settings area no worries.
Not sure about RMS though...
Just don't forget to change your clock back or normal browsing won't work.
That is old school - nice work!
NI-DVX - there is a module that adds the switcher pages back as HTML
NX-DVX - module works, but there is also firmware
RMS - there is a software update that brings HTML5 AND fixes legacy mode support
We anticipate RPM getting an update that has the module included to aid those users as well.
