Home AMX User Forum AMX Resource Management Suite Software
Flashplayer is out of date
hello… since yesterday Flash player is out of date and for security reasons was blocked to the browser into my office...I no longer know how to open Classic IU in RMS....is there any way around / fix this problem please ?
  • HARMAN_RobHARMAN_Rob Posts: 230
    edited January 2021
    RMS Enterprise 4.8.0 is available for download on AMX.com:
    https://www.amx.com/en-US/products/rms-ent
    Changes in this release(4.8.0)
    -- Classic FLASH-based UI pages have been migrated to HTML.
    -- Now 'Search' windows return the set of entries which 'contains' the
    specified "search string". Wildcard search characters(* or ?) are not
    supported in the "search string".
    -- 'Context Menu' options that were available in RMS 4.7 are now supported
    as buttons and/or icons for a better browser experience.
    -- Legacy SDK Devices connection issue is resolved.
  • If you are unable to update your RMS implementation, you can leverage (for a few more months) the Adobe Enterprise Enablement feature. I did a quick search on Adobe Enterprise Enablement - here is a video of a user creating and placing the config file to enable Flash on your device.
    https://youtu.be/nOcW1Ugt7Mk?t=96
  • simosimo Posts: 8
    Did anyone have any luck using the above method to access a DVX switch web interface? I tried this but just got a blank white screen
  • HARMAN_ChrisHARMAN_Chris Posts: 597
    edited January 2021
    Another option would be the Flash Player Projector Debugger available on this page: (https://www.adobe.com/support/flashplayer/debug_downloads.html )
    Or from this direct download link:
    https://fpdownload.macromedia.com/pub/flashplayer/updaters/32/flashplayer_32_sa_debug.exe
    The debugger is a standalone flash player that runs without a browser on your computer. If you put the address of your DVX switcher flash file in as the file to open you can still access the switcher setup on the DVX. Enter this in the file open dialog: http:///web/http/dvx_hd.swf
    This even works when the DVX is remote, and with hostnames
  • John NagyJohn Nagy Posts: 1,734
    Note that the direct download link, if clicked as is, results in a 404 not found. You need to remove the closing parenthesis ")" that comes with the link as typed. The same is likely if you copy the file open link to the DVX.
    edited January 2021
    Updated - my apologies
  • simosimo Posts: 8
    Tried the "Flash Player Projector Debugger"
    But getting the following error messages and cant control any DVX Ni or NX units Ive tried:
    "An Actionscrict error has occurred"
    TypeError: Error #1009: Cannot access a property or method of a null object reference.
    at com.amx.dd.models::AppModel/setValuesFromXML()
    at com.amx.dd.controller::LoadSettingsCommand/onPageResults()
    at flash.events::EventDispatcher/dispatchEventFunction()
    at flash.events::EventDispatcher/dispatchEvent()
    at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
    at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()
    at mx.rpc::Responder/result()
    at mx.rpc::AsyncRequest/acknowledge()
    at DirectHTTPMessageResponder/completeHandler()
    at flash.net::URLLoader/onComplete()
  • Surprised this worked for me...
    1-Set computers clock back by a year, pre 2021.
    2-Opened oldschool Internet Explorer.
    3-Opened older DVX (2155) and was able to access the DVX Flash/AV Settings area no worries.
    Not sure about RMS though...
    Just don't forget to change your clock back or normal browsing won't work.
  • That is old school - nice work!
    NI-DVX - there is a module that adds the switcher pages back as HTML
    NX-DVX - module works, but there is also firmware
    RMS - there is a software update that brings HTML5 AND fixes legacy mode support
    We anticipate RPM getting an update that has the module included to aid those users as well.
