RMS 4.8.0 - The RMS configuration file 'flex-settings.xml' could not be found
mavdieie
Hello forum,
Does anyone have the problem with creating configuration/flex-settings.xml
during the installation process of RMS 4.8.0?
I can create this file manually and passed the tests in diagnostics tool but maybe this file include valuable configurations that will be need to run the RMS?
Thank you.
On version 4.7.0 file created successfully
Thank you for posting this. Technically, there should not be any Adobe Flex elements in 4.8 so this is interesting. I checked with the support team assisting with RMS installs and upgrades and this is a new one for them. What was the process you followed in the install - meaning:
tried a clean install of 4.8 on a server with no prior RMS install -> failed because of configuration/flex-settings.xml-> then tried 4.7 installer -> success -> upgrade via 4.8 installer -> success ?
I am trying to confirm to get this info into support in the event this is a bug they can recreate.
I too have this same problem on a new installation...
I am installed the 4.8 on a new server when I am started this discussion. And I am found workaround (for passing the tests) - installed RMS 4.7 -> get file from that version -> delete 4.7 and all config files -> install RMS 4.8 -> put the file to
C:\ProgramData\AMX\Resource Management Suite\Server\configuration
