Sony Qualia 004 projector
I have to connect a qualia to a ni-3000 using 232 and not ethernet. The problem is AMX doesn't have a published module for 232 control only ethernet.
I talked to a Sony engineer and got the following hex strings...
Power ON
Sample A9 17 2E 00 00 00 3F 9A
Power OFF
Sample A9 17 2F 00 00 00 3F 9A
Picture Mute ON
Sample A9 00 30 00 00 01 31 9A
Picture Mute OFF
Sample A9 00 30 00 00 00 30 9A
These are working fine and show me the 8-bit format of the commands. Yet, the engineer didn't send me the only other 2 commands I really need (HDMI and DVI discrete input commands). I tried using the Qualia protocol guide that AMX has on its webiste (included below) but I haven't been able to piece together what the 2nd to last bit should be (the checksum).
this is what I think they should be (without the checksum)
$A9$00$01$00$00$05$(--)$9A
$A9$00$01$00$00$04$(--)$9A
anyone else any good at figuring out checksums from the protocol guide? TIA
Power ON
Power OFF
Picture Mute ON
Picture Mute OFF
However, when I look at device notifications this is what it says... is this because of some kind of data check? why do the strings not equal each other?
The strings do equal each other, they?re just presented in a different format. Device Notifications will display the ASCII value of a byte when it?s a printable character.
The third byte (the . period) is the ASCII representation of $2E and the next to last byte (the ? question mark) is the ASCII representation of $3F.
This popular 70?s band consisted of an ex Beatle?
Excuse me Alex. I said Silly Checksums for $100, not Silly Love Songs
My bad. This Silly Checksum is the same for both of the HDMI and DVI discrete input commands that Jarrette wants to implement.
What is $05?
I'm sorry, you forgot to state that in the form of a question...
And you threw me for a few seconds with that "What is $05" question until I got back into the Jeopardy frame of mind.
// Calculate check sum by OR addition
DEFINE_FUNCTION CHAR getCheckSum(CHAR strInput[]){
LOCAL_VAR INTEGER i;
LOCAL_VAR CHAR strOutput;
i = 0;
strOutput = $00;
FOR(i=1; i<=LENGTH_STRING(strInput); i++){
strOutput = strOutput BOR strInput;
RETURN strOutput;
Hope that helps.
-Chadd
