Cafe Duet Plugin
HARMAN_icraigie
Since the original licensed required Cafe Duet application has been "discontinued" we have made available a no cost option as a standard Eclipse plugin (Version: 2020-06 seems to work best). The package will contain all core libraries from the NI and NX controllers as well as other relevant ancillary material.
For any one interested PM me here with your email and I will forward you the download link.
Links to materials in Developer Resources:
The Plugin and references
https://developer.amx.com/assets/uiResources/Duet%20Developer/Design%20Feature%20Plugin/files/Duet%20Design%20Feature%20Plugin.zip
Cafe Duet Class materials and other miscellaneous stuff
https://developer.amx.com/assets/uiResources/Duet%20Developer/Class%20Materials/files/Cafe%20Duet%20Class%20Material.zip
Hi, I have licene but old computer is not working. What is the possibility install for the new computer?
Our suggestion is to load the standard Eclipse environment - no license needed. If you must install Cafe Duet, get with support because there are some back-end hoops that need to get worked out for you.
Hi, I wrote to Mr. Ian Craigie (PM) as per original post by him, as I am interested in the Eclipse plugin, but I got no reply. Is anyone here reading who could provide the mentioned package? Otherwise where should I ask?
Check you're inbox here - replied to your request last Monday.
Thank you for replying Mr Craige, but there must be something wrong with my account, because I got no message in the box here. Would you please be so kind to resend that answer to my email address ( lt at arocom.ch ) ?
Thank you very much
Luca Trisciani
Thank you, Mr Craigie. Now I got your mail!
OP updated with the Developer Resources links.
The Plugin and References link has been updated with com.amx.duetdesign.p2repository-3.2.3.
This revision adds the packed jar manifest items required to run a Duet module on a MUSE controller.
The packed jar also requires a descriptor which can be added through this tool:
https://developer.amx.com/beta/muse/descriptor/#!/main
Thank You for sharing!
