Need Bose CSP-1248 control manual or module
kishormohiite
Hi,
I am programming for controlling Bose DSP model - CSP-1248 on TCP/IP with AMX NI-3100.
I have got a document stating few commands like setting/getting volume & mute. But I also need commands to recall a preset set on CSP.
Does anyone have idea where I can get those commands? I searched for a control manual on Bose website but there is none. Also, there is no module available by AMX for this device.
Any help with module, control manual or a sample code will be great. Any other suggestions are appreciated too.
Thanks in advance.
I searched for Bose CSP-1248 RS232 control protocol and found this - is it what you need?
https://assets.bose.com/content/dam/Bose_DAM/Web/pro/global/products/software/ControlSpace_Designer_software/downloads/ControlSpace_5.3.2_SerialControlProtocol.pdf
Thanks for the link for manual. But this manual is only for ESP,EX, Powershare & Powermatch series. Bus sadly not for CSP series.
I checked with AMX support team. and they have suggested that there is no facility of setting/recalling presets for CSP series since its a fixed config dsp. So my search for commands end here.
Anyways, thanks for your reply and kind help.
Thanks!
Hi Kishore,
Can I get the TCP commands. Or can you tell me where you find the commands. Because I need to integrate CSP-428 in one of my project.
@kishormohiite: can you share a document stating few commands like setting/getting volume & mute for bose CSP-1248? Appreciate if you can share. I have the same on going project to control the CSP-1248 but I cant find the control protocol.
