Motorola Cable Box
Has anyone developed a reliable way of determining the current power status of Motorola cable boxes? The two methods I am toying with are: a 12v power supply plugged into the cable box and driving a contact closure or an LED sensor. ELAN makes an LED sensor, but I have to supply 5v (think they chose 5v instead of 12v to make me have to work). As for the power supply, I have to find the menu to make the power output of the cable box reflect the power status of the box.
Any ideas would be appreciated.
Then from there, he hooks it up through a 12v power cube to Elk relay to give contact closure on the I/O sensor on the master. Then I just use a simple IF/ELSE to power on and off the box:
Double check advanced setup (setup button twice) there might be an option to have numeric keys power on the unit. I assume you don't want to turn it off. Also can possibly set timer to turn on every morning. Scientific Atlanta boxes generally have these options.
Bill
My installers have seen this twice in the last month.
If you decide to use the led sensor i would say that you need to put the sensor inside the cablebox for best performance.
