Home AMX Technical Discussion
AMX NI-700 programming to control a projector
Hi there everyone im relatively new in the AMX programming world and we have an old solution that uses an ni-700 to turn a projector on with a ground t ground contact on input 1 and it will turn the projector off with a input on input 2 the old projector is on its last legs and we had different people do the programming years ago. Now though we purchased a new optoma zh-400 projector that has rs-232 capability i had even plugged it into my computer and was able to putty into it and send it the on command which is ~0000 1 and it worked but after doing some programming i havent been able to get the AMX device to power on the projector i was wondering if i have made any errors in my programming as i am new i can link it below
PROGRAM_NAME='Main-HH'
(* FILE_LAST_MODIFIED_ON: 03/06/2024 AT: 08:45:25 )
System Type : NetLinx )
REV HISTORY: )
$History: $
DEVICE NUMBER DEFINITIONS GO BELOW )
dvMansionProj = 5001:1:0
dvIO = 5001:4:0
CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
ioPowerOn = 1
ioPowerOff = 2
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW )
EXAMPLE: DEFINE_FUNCTION () )
EXAMPLE: DEFINE_CALL '' () *)
(* STARTUP CODE GOES BELOW *)
(* THE EVENTS GO BELOW *)
DATA_EVENT[dvMansionProj]
ONLINE:
SEND_COMMAND dvMansionProj, "'SET BAUD 9600,N,8,1'"
CHANNEL_EVENT[dvIO,ioPowerOn]
ON:
SEND_STRING dvMansionProj, "'~0000 1'"
CHANNEL_EVENT[dvIO,ioPowerOff]
ON:
SEND_STRING dvMansionProj, "'~0000 0'"
!!!! WARNING !!!! )
Due to differences in the underlying architecture of the )
X-Series masters, changing variables in the DEFINE_PROGRAM )
section of code can negatively impact program performance. )
See “Differences in DEFINE_PROGRAM Program Execution” section )
of the NX-Series Controllers WebConsole & Programming Guide )
for additional and alternate coding methodologies. *)
DEFINE_PROGRAM
(* END OF PROGRAM )
!!! DO NOT PUT ANY CODE BELOW THIS COMMENT !!! )
  • I think the commands to the projector should be terminated with a carriage return:
    SEND_STRING dvMansionProj, "'~0000 1',$0d"
    Agreed - the PC application is likely applying carriage return and possibly line feed without user intervention.
