Sending CGI Commands Via Netlinx Using A TCP IP Connection
Dear Guys
I need to send CGI Commands to a Sony equipment with a netlinx controller .
The commands sent via a Browser have the following sintax
"http://PedroSerras:PedroSerras@50@192.168.1.96/analytics/analyticsbox.cgi?Active=on"
PedroSerras is the user name and PedroSerras@50 is the password
another command withou password :
"http://192.168.1.96/command/inquiry.cgi?inq=system"
Could someone tell me what are the headers and footers that i need to add to the string sent via an TCP Ip Client connection ?
The TCP Clinte >Connection is open in the Port 80
thanks in advance
This sample may help you to build the http command, rename it from txt to axs. Comments are in German, sorry
Thanks a lot Mark
I saw today your answer
regards
