G4 Panel Builder
Spire_Jeff
Does anyone use this on a regular basis and how much has it helped you? I am currently thinking about revisiting this program for a second try and I want to make sure I give it a fair shake. To unleash its full potential, do I need to create my own templates? Any other pros or cons that I should be aware of?
I don't believe there is a way to have the panel builder set codes, and if there is, I never saw it as an option.
It's good to create a base to work with but you need to spend hours to days customising the result, so a static template file is just as useful.
It would be great if you could put some permanently available buttons on it like power, volume and lighting.
These wizard programs come out promising the world, making the boss and all sales staff believe it will only take 10 minutes to do an entire panel.
I pity the customer with the industrial steel design on their panel!
By tweaking the templates, you could really rock with G4PB, and it could take you about thirty minutes to an hour to do a complete panel. Sure the initial tweaking wouldn't take you this long, but after you spend a day tweaking the template how you want it (or any template that you've made) G4PB seems to have the potential to really save you time and money in creating touch panels.
Just my opinion . . .
I've had to modify them of course.
