Home Scripting Languages
Communication between programs
Hi
Is there any possibility of inter process communications?
Some common objects or virtual device visible for all programs, Node-RED, JS etc.
Any way to trigger JS function from outside, from another JS program or Node-RED flow?
  • The only ideas I have at the moment are to use shared files between the scripts and Node-Red, or to open network connections internally on different ports between scripted and Node-Red clients and servers.
    For file solution, find attached a little document I did about the file path dependencies when doing file operations in scripting and Node-Red.
    I have not tested yet if the relative path could be done and working in a way that Node-Red and the scripts can reach each other's default file folder, but I think it should work.
    But that's not a suitable solution for "realtime" data exchange.
    Regarding internal network connections, it should be possible to create e.g. a TCP server in Node-Red, and a TCP client in a script on on an unused IP port number, to send and receive data forth and back between the scripts and Node-Red. (don't know if "localhost" IP 127.0.0.1 will work)
    Only food for thought....
  • I'm not using Node-Red, nor JavaScript, but in Python I have used Unix sockets.
    This looks like it might be a solution for Node-Red? node-red-contrib-ipc
    Until NodeJS is available, one would be limited to WebSockets only in JavaScript. Once again, I have not looked at Node-Red but I'm sure it has WebSocket support.
  • Can't tell much at all, but I've heard there may come updates to Muse, which may include a way to directly interact between scripts (and so maybe also to Automator).
  • ychych Posts: 51
    Muse hasn't been updated for a long time, will it support Netlinx Studio in the future?
    If you mean "will Muse support NetLinx programs"... imho I don't think that this will happen, at least not short term... NetLinx e.g. is based on device addresses (number:port:system), where Muse is based on IP addresses (panel gets connected only by IP address). Personally I see the ICSP protocol support in Muse more or less just "legacy"
    If you do e.g. a Python code, you can set up the script similar to a NetLinx code, like defining device names for each panel port, and also simply said you have event handlers that react to a push and release from the panel, that then can call functions to be executed.
    Beside of the language syntax itself, the visibly difference is that in NetLinx, most of the instructions a push should do, is written in the Push section of a button_event.
    In Muse scripting, when the "button event" gets triggered, it calls a function where all the stuff to do is done, on Push and Release action.
    And: "there finally is no more mainline" :)
    If a NetLinx code is written well, even now everything is triggered by events, nothing done in the idle define_program
    In Muse scripting, the is no other way to do it like event based :)
    Personally, it would be nice to have a library (kind of "import netlinxLibs") for the scripting languages, to get predefined functions that operate like the NetLinx commands. so e.g. we would have kind of a simple
    result = netlinxLibs.removeString(,,)
    that works 1:1 like in NetLinx.
    You can do e.g. a remove_string also in the scripting languages, but some things are more complicate.
    hmmm..... might be an idea, to write a little NetLinx sample and e.g. a Python equivalent....
    There is a library of IP communication functions at the AMX Git Hub:
    https://github.com/amx-itg/muse-driver-amx-ipcomm
    This jar can be imported like a Duet module into the Muse controller, and provides several different IP communication handlers for Groovy, Javascript and Python.
    I haven't used them yet, but....
  • ychych Posts: 51
    I have tested muse groovy a few months ago, but debugging is very time consuming, there is no compilation function, and errors are difficult to find. Will the jar sdk of muse be opened later? Programming with idea is also available with third-party packages from the maven Store!
  • Sigh... I just posted a large comment, and the forum seems to have lost it!
  • Here is the gist of it again, from memory!
    NetLinx will never be supported on MUSE, it's an entirely new platform designed to bring AV programming into modern software development.
    Honestly, learn Python. It's just as easy to program as NetLinx. If you need to figure out how to do something, there is a 99.9% chance there is an answer on the internet. It's the world's most popular programming language.
    I generally don't use any vendor supplied modules and the Duet IP comms module is just an unnecessary extra layer of abstraction and configuration. I have written a Python package that uses Python's asyncio and AsyncSSH to provide an event driven interface to TCP, UDP, SSH, and SSL/TLS sockets that works just like events in NetLinx. It uses Python decorators to be able to write code like this:
    @data_event(<some event qualifier like socket client>, <some other event qualifier like 'online' or 'string'>)
    def some_event_handler(<event parameters>...):
        # do something here
    I was fairly new to Python when I wrote it and cobbled it together using the asyncio documentation and hints from StackExchange.
    With Python, it's totally possible (because I am doing it already) to write control code that runs on any platform that supports Python. MUSE (absolutely the best controller platform! B) ), Crestron (4-Series), Extron (when they upgrade their decrepit Python version from 3.5!), Windows, Linux, Mac.
    I do all my development in WSL2 Ubuntu on Windows. Run the code directly on the laptop, test and debug. When it's ready to deploy, load it on to a controller. It takes literally seconds to restart a script and test changes. Compared to the compile/upload/test/modify cycle, it's so efficient. If you're concerned about no compiler to pick up errors, then use type hints and enable strict type checking in Pylance. Pylance and Pylint are very good at picking up errors as you develop, no compilation necessary. I recently wrote some code in Simpl#Pro (See this post), it was orders of magnitude slower than writing in Python, both in the compile/upload/test cycle and in the number of lines of code required.
    NetLinx was, and still is, a great language. It's just not capable enough in today's IoT world. One simple example is parsing JSON. In Python it's literally one line of code. In NetLinx it's painful. Back in the day, I ported jsmn to NetLinx and wrote a function to convert the parsed JSON to XML for use with XML_TO_VARIABLE, but it still required a one-to-one correlation between the JSON and the struct it was being decoded into.
  • ychych Posts: 51
    muse should have java sdk, I have been looking forward to the release of jar, and I use idea to build programs. idea has very powerful functions, but I am not sure whether muse supports.NET in the future. If yes, the same code can be slightly modified to adapt to crestron. You can also build your own win form to use as a control screen!
  • Why would you use Windows Forms for a UI?? Just use HTML5. React, Typescript, and WebSockets for a completely cross-platform solution. Host the HTML UI on the controller and run a Varia panel in web-kiosk mode.
    I can't say definitively , but I highly doubt they are going add .NET
  • New firmware is available and we have a new programming guide to go with it. Check out pg. 36:
    Exporting Script Functionality in the 1.2 version of the programming guide. Essentially, you can modify the program.json to expose your script as a muse device. I haven't tried it, but this appears to be the canonical method to achieve communication between processes, regardless of of weather its javascript, python, or groovy.
  • I am having trouble with py file management. How do you separate tp input defines for controlling multiple devices so py files can be reused like an include file for each server device?
