Vantage Lighting feedback from virtual 250 button LCD
Has anybody used a virtual 250 button LCD in the Qlink program for integration purposes? Using the AMX comm module and the driver looks like it does not acknowledge the 4byte feedback (aot the standard 2byte data), as a valid response and does not report an LED change correctly. Before I go through the hassle of extending the driver are there other options?
  • I haven't had an issue watching or pressing a Vantage LCD with AMX. Which LCD type are you using?
    Kevin D.
    Kevin D.
    C5V-W. Raw data out of Vantage is does not follow the protocol guidelines.
    Standard keypad LEd change
    String From [5001:3:2]-[LE 2 48 40 00$0D]
    LCD LED change
    String From [5001:3:2]-[LE 1 28 8041 00$0D]
  • If it's virtual, use the 320M.. That's all I use.
    Kevin D.
