VNC client on VARIA
Hi,
Is there a way to get back application windows in tpd5 and VNC support? I can't get this to work and i hope AMX didn't remove that functionality from there panel.
Best regards
  • Duncan EllisDuncan Ellis Posts: 172
    VNC works.
    I've used it
  • neoguirineoguiri Posts: 32
    @Duncan Ellis said:
    VNC works.
    I've used it
    Yes it is but not the way it was before as a application windows inside tpdesign5... it was too simple and straight forward i supposed. Do you know the way to open a vnc direct connection from the send_command? Like adding the IP in the parameters of the send_command. To avoid the step of the bookmark on the VNC client?
    Load a VNC app for Android onto the panel and ue the ^App command to launch it
    Thank but like i said before, you can't recall a direct connection to a vnc client by doing this.
