Remove String with a Hex D
Greetings,
I have a device that sends a $0D as an end of transmission. I would like to remove all before the $0D as my message from the device.
REMOVE_STRING (cMESSAGE,$0D,1) does not work. I am assuming because $0D is not a printable ASCII character.
Does anyone have another suggestion?
System is Netlinx.
Thank you.
  • Is it sending hex or ASCII that's hex codes? If it's sending HEX, have you tried (cMESSAGE,"$0D",1)?
    Kevin D.
  • champchamp Posts: 261
    Try REMOVE_STRING (cMESSAGE,"$0D",1)
    or to debug it
    IF (FIND_STRING (cMESSAGE,"$0D",1)
    SEND_STRING 0, 'I found a carriage return'
    Also if you are reading DATA.TEXT, then you could not get all the text at once as it overwrites itself every time new data comes in.
    If you use a buffer then the string concatenates itself with new incoming text
    ...removing strings and characters takes more processor power but probably only matters when using an Axcent.
    It's sending a hex 0D which is equivalent to a decimal 13 or an ASCII carriage return. I do not know how to specify that in a REMOVE_STRING command.
    You've got it right
    specify it as "$0d" or "13"
    by surrounding it with "" you make it a character string literal of length 1, whereas without adding the "" the program is looking for an integer which it'll never find in a serial string
    REMOVE_STRING returns everything up to and including the search string in question. So if you want everything before the $0D, you?ll have to add one more line of code like SET_LENGTH_ARRAY, SET_LENGTH_STRING, or RIGHT_STRING to lop off the terminating carriage return of your message.
  • this is one way to clean it up ...
    define_constant
    char EOL_CHAR[1] = $0D
    integer MAXBUFFER = 128
    define_function char[MAXBUFFER] RemoveEOL(char in_string)
    stack_var integer EOL_LOCATE
    EOL_LOCATE = FIND_STRING(in_string,EOL_CHAR,1)
    if(EOL_LOCATE) SET_LENGTH_STRING(in_string,EOL_LOCATE-1)
    // no need to return variable string seperately, it was modified directly
    // within this function. but we will return it as an example
    return in_string
    .. now from anywhere in your program state
    RemoveEOL(SourceString)
    And kiss anything that might be past EOL_LOCATE goodbye, so don't do this to an incoming buffer attached to an RS232 port, right? :)
  • yeah, your right, it does truncate the string, and i forgot to mention that.
    what i sometimes do is use the result EOL_LOCATE to actually split the string. (compare LENGTH_STRING(in_String) to EOL_LOCATE).
    you can create the tail string with something like this in the RemoveEOL()..
    if(EOL_LOCATE<LENGTH_STRING(in_String)
    tail_string = in_string[EOL_LOCATE+1]
    else
    tail_string = ''
    return tail_string // instead of return in_string
    before you set the new length of in_string.
    the function could then return the tail string, as it had modified the source string internally. then, when the function returns, check length of tail_string, and do it again if need be (do-while-loop).
    char tail_string[MAXBUFFER]
    char check_string[MAXBUFFER]
    check_string = SourceString
    do {
    tail_string = RemoveEOL(check_string) // new version, must return tail from example above (i've place full example at the bottom)
    .... do something with check_string here....
    .... and then .....
    if(LENGTH_STRING(tail_string))
    check_string = tail_string
    } while(LENGTH_STRING(tail_string))
    i had left it simpler in the other example, i based it on an assumption of not expecting more in the line, that we just wanted to remove EOL.
    so Chips warning is quite valid. watch out for truncating :)
    <code>
    define_constant
    else
    tail_string = ''
    return tail_string
    </code>
