Home AMX Technical Discussion
VNC Server on Varia 150 Crash after some times
Hi AMX,
Is there a chance to see an update of the Varia 150/Android firmware with a stable VNC Server any time soon?
Every time i don't know exactly after how long i need to go physically on the panel to restart the VNC server to be able to connect again. And it's really not practical. No problem at all on G5 products, only the Varia 150. And on several one not only one. And also a fix for the rtsp stream in dynamic images problem?...
Best regards
  • a major update is coming early April
  • neoguirineoguiri Posts: 39
    Ok thanks
  • The new Varia firmware v2.13.16 is out now.
    Yes i saw that but i hvae a problem to run Manager now... Problem i forgot but that was there since the last unpdate of that soft.... As usual i'm the only one... and no update since a year from AMX...
    Honetly i don't know what to say!!! We have the same problems on this release.... So i supposed we have to wait one more year for a new update that will not solve the problems!!!! AMX is still so good!!! I have no words... Thanks for those amazing devices...
  • emdx71emdx71 Posts: 51
    Just wanted to chime in and say that we're actually seeing the vnc not respond more often now, I've been finding I have to run manager, disable vnc then re-enable vnc to be able to connect on all the panels I've updated to 2.13.16
    Yes that's the way a i do it too...
  • Any news on that or as usual we are left with bugs and problems never solved? Like the super soft manager that have no update since more then a year... See my post in may... Did harman then samsung bought AMX to let it die?!
  • current Varia firmware is 2.13.19... https://www.amx.com/en/softwares/varia-touch-panel-firmware-v2-13-19
    Bigger releases in Varia and Muse are coming when the BSS Omni and the AVX Suite environment gets released.
    Regarding the Manager Software, I saw an "AVX Manager", that works faster, more reliable, and e.g. is grouping all Muse-internal devices into a folder, instead showing them all individually.
    Hi Marc,
    Thanks for the answers!
    I will try this version but they are not speaking about the VNC problem/crash and look like the Streaming problem/reboot is still there :(
    Do you have a idea when the Manager will be released?
    Best regards
    Hi Marc,
    Unfortunatly and as usual i would say the bug of the VNC is still there... The bug of the streams and memory as well and there is no mention about the bug of the images in buttons that are replaced by other images randomly.
    As usual we move forward with AMX...
    Best regards
  • I'm not aware of bugs with images in buttons...
    I only can recommend to report any findings to Harman Tech Support, the more reports, the better
