IR Edit 2 "Data" field.
So it looks like the Data field populates with decimal values when you capture an IR function. My initial assumption was the values could be converted to 4 character hex for portability to other systems, but I'm not entirely sure this is the case. The results do not jive with the expected IR Hex Codes I got from Global Cache, but until I implement them I will not know.
Any reason AMX formatted the "data" in decimal instead of standard 4 character hex?
Any thoughts? And can we get that format changed for future releases?
Captured IR can vary slightly due to conditions during capture and still work. "Close enough" is apparent when comparing working codes from different sources that show some differences when examined at the digital level. Sometimes there are repeats included that may or may not affect the target device. You won't know til you actually load and go. That said, yeah, it would be rational to include the widely used "pronto" 4 character format... when there are too many "standards", there's always someone who says adding a new "standard" is the solution.
