WinMAX Issue !!!
Hi,
I would like to know if someone else encounters that issue with WinMax 3.0 Build 2 when used with Windows 2K and Windows XP. Each time you change of tab and when it starts, you get the Sysinfo error but it looks without consequence.
When you want to add a new DVD to MAX Server, when you click on Identify, we get the second error and no way to continue. So we are unable to add DVD to MAX as it's a version of AMX without DVD player included.
THanks for your ideas
Vinc
Vinc
Also, you may need to Select the drive for the DVD/CD. go to Application Settings/config/DriveNum and try changing that to 1 for an external/extra drive. (i've seen this NOT work on notebooks with docking station based DVD drives, but it's worth checking).
and another thing.. you may not have the correct region of dvd related to the pc. there are third party applications for setting/overriding the region. an example is AnyDVD.
I discovered when i use WinMax to upload a group of MP3s(tags editted to put all in same artist/album/year), that after uploading WinMax will not allow me to click to upload another collection of MP3s without shutting down and restarting WinMax.
Anybody else have this problem?
**UPDATE**
Must have been a Windoze problem after rebooting my laptop, problem went away
