Integrating Alarm Systems
Impaqt
THis is something that I have not done much with and have a couple clients interested in doing more thanjust the basic Arm/Disarm stuff. In the past I've integrated the Ademco Vista Module and that was about it....
THis particular client want to be able to set the system to OFF.. Easy, Away... Easy... But then want 2 different Stay modes.. One with Some motions active and one with no motions active.... and also a "Chime" mode for doors.... (Does not want chimes when system is DIsarmed)
I would assume these Modes would be set up int he Alarm system programming and not necessarily my AMX code.
Will a Basic Ademco VIsta 20 do this? Can you access these modes though a standard Keypad interface?
ANy guidence would be Apreciated.
John
John
Not sure that I've seen two stay modes before. Maybe some form of away arm with certain motions bypassed. That would take a string of keypad pushes.
On the second part, how can you have a chime mode in the armed state only? As soon as you open the door the keypad will start beeping wanting a disarm code.
Kevin D.
What you can do with the Vista 20 is to use the partition portion of the Vista Panel. The Vista 20 has 3 partitions, put some of the motions in partition 2, and others in partition 3. That way you can arm that partition separately from the others, and can also be done by user code.
That said, I've only had any real experience with integrating the Napco Gemini, and that was minimal (plugged in the AMX comm module, slapped together a UI, and that was it).
I'll have the alarm guy set the partitions up for the motions. THat sounds like a good plan.
THanks
In that situation we wound up putting a toggle switch going to the keypad speaker. "Flip this up if you are going to be sleeping and don't want your daughter coming home and waking you up".
Kevin D.
