Extron VIdeo matrix
I am trying to program Extrom video matrix, and i have a problem with command to do that.
All I need is to pust two buttons on TP , and to put that to command.
Example:
push tp,1
push tp,2
send_string 'input 1 on output2'
  • If the Extron Device is using the SIS protocol:
    PUSH[dvPanel,1]
    SEND_STRING dvExtron,'1*2!' // route In1 to Out2 both Video and Audio
    '!' is video adn audio
    '%' is video only
    '$' is audio only
    Baud rate is 9800,N,8,1
    To disconnect a route AFAIK it's
    PUSH[dvPanel,2]
    SEND_STRING dvExtron,'0*2!' // disconnect route to Out2, both video and audio
  • VladaPUBVladaPUB Posts: 139
    I have understand that, but how to push two buttons, and create from that one command ?
    I mean , when I push button 3 and button 1 to create command '2*3!'
  • I misunderstood, sorry.
    INTEGER nSource
    INTEGER nDest
    DEFINE_CALL 'SwitchExtron'(INTEGER In, INTEGER Out)
    SEND_STRING dvExtron,"ITOA(In),'*',ITOA(Out),'!'"
    DEFINE_PROGRAM
    PUSH[dvPanel,3]
    nSource = 2
    PUSH[dvPanel,1]
    nDest = 3
    IF((nIn>0) AND (nOut>0))
    CALL 'SwitchExtron'(nSource,nDest)
    nSource = 0
    nDest = 0
    OK, this some kind of rudimental..... Depending on your experience and AMX platform there are a lot of solutions possible.... ;)
    Very small experience, but all people from this forum helps me a lot. Thank you !
  • Assuming you have more than one input and more than one output:
    PUSH [TP,1]  (* these are sources 1-8)
    PUSH [TP,2]
    PUSH [TP,3]
    PUSH [TP,4]
    PUSH [TP,5]
    PUSH [TP,6]
    PUSH [TP,7]
    PUSH [TP,8]
      CurrSource = PUSH_CHANNEL
    [TP,1] = (CurrSource = 1)  (* Let's light up the active source button *)
    [TP,2] = (CurrSource = 2)
    [TP,3] = (CurrSource = 3)
    [TP,4] = (CurrSource = 4)
    [TP,5] = (CurrSource = 5)
    [TP,6] = (CurrSource = 6)
    [TP,7] = (CurrSource = 7)
    [TP,8] = (CurrSource = 8)
    PUSH [TP,11]  (* once you select a source, then you can select where you want it to go *)
    PUSH [TP,12]  (* these buttons are for destinations 1-8 *)
    PUSH [TP,13]
    PUSH [TP,14]
    PUSH [TP,15]
    PUSH [TP,16]
    PUSH [TP,17]
    PUSH [TP,18]
      CurrDest = PUSH_CHANNEL - 10
      SEND_STRING Extron,"ITOA(CurrSource),'*',ITOA(CurrDest),'!'"
      (* You get to figure out how you want to do code for the destination buttons.  :)  *)
