Differences Between Mvp 7.5 And 8.4
Is there anything major?
I know one is active and one is passive. Ive only worked with the 8.4's and have found them very good.
How different is the 7.5 (apart from the price difference). How is the connectivity to a wap??
7500 - 12 bit color depth (4k colors)
Fred
The other 4 Modero's are graphic intensive still waiting on the firmware upgrades for that for VNC and split screen issues.
one other shortfall of the 7500 compared to the 8400 is that by default you only get one battery. an extra battery is included with the 8400 (so the AMX website says).
otherwise, networking etc all appear to be the same. so if battery and visuals are not so important (yeah right, smaller with ghosting
oh, and the 7500 is a bit lighter. that can be a benefit to physically challenged users.
You have to basically avoid stright edges in your touch panel designs at all costs. It is a problem if you want to use a common panel design.
I like the viewpoints!
RF has a lot less issues than the 802.11 panels.
If AMX only brought out slimmer versions of viewpoints with more than 255 button capability I'd be set.
One other comment - I use degrees of transparency sometimes on 8400s to make "less important" icons less obvious or to highlight more vividly a selected source. This is not even an option when using 7500s. Double check that everything is 255...
Bill
and the transparency issue is very valid. i am just redoing an 8400 design, have a lot of transparency, now i'll have to rethink that to make it 7500 compatible.
as for RF, you can use it from the MVPs if you want. it's there ready to go.. all 255 buttons
i agree with champ. there is a compromise, but you pay a lot less for the 7500. it's generally fair.
I have stopped using the 7500 too - It may be my impression, but the 7500's touch overlay seems to be really bad and I have encountered at least two panels where touch areas could not be made to match the graphics closely enough to reliably select a 60Wx35H button. The 8400 appears to fare much better in this (and other aspects mentioned before).
(For that matter - I still don't understand why AMX abandoned the reliable 8-point calibration - this really should be re-introducted as 2-point calibration is highly in-accurate)
I completely agree with you.
