Samsung PPM42M5H - Ignores ON command
Has anyone else had to control a Samsung PPM42M5H unit?
I am finding that it ignores the RS232 ON command and that the ON command needs to be sent several times.
Once it is on, the source selection and power OFF work perfectly.
It is only the power on.
I have tried the chard command at various delays, but it does not seem to make a difference.
I had a problem like this with the NEC GT-5000, turns out I had to set the unit to a stand-by mode rather than ON/Off. Took awhile to figure it out because sometimes if I burst the "ON" command it would work.
Hey Thomas, the only command I can find for this unit is power (there is no standby etc).
I have controlled Samsung plasmas in the past, but this is the first one I have come across where the baud rate is 9600 instead of 19200.
The last Samsung I controlled was the PPM50H3 and it has the same protocol except the baud rate is 19200. It worked okay.
Of course to add fun to this, I am doing the work remotely.
Can?t comment on Samsung but I had a similar experience with a Fujitsu that has a protocol in the format of:
Me --> Hello
Fuj --> OK
Me --> Do this
Fuj --> OK
Me --> Goodbye
When the Fujitsu was powered off it didn?t always respond with an OK after a Hello was issued. The routine had to ask Hello several times (in x second intervals) before it eventually got back an OK and then once the OK came it could issue the Do this. After the unit was powered on it always responded to a Hello the first time. Also in between the time of Hello and Goodbye, the front panel and IR is disabled.
The NEC wasn't a command per say but was in the projectors OSD menu setup. After I changed it the units worked ever since.
Not being on site, I can not say 100% if there is anything in the setup menus of the plasma.
But knowing the person ( I have a lot of confidence in them) on site and they said they went through the menus and did not see anything, I have to believe that there is no setting that can be changed.
Cheers,
Bryan
P.S. Sorry I spelled your name wrong. Bryan
Did you get the problem resolved? I was thinking about it and wondered if the unit gave RS-232 feedback when it was on, a status command or something. If so, then run an IR cable to the unit and just pulse the power on command via IR and all the other commands via the RS-232. Not fancy but a work around till you figure out the issue.
Also, I talked to another programmer and he was using PPM50M5H and the plasmas are doing the same thing, he also had to send the on command 6~8 times for it to work.
Basically, the unit goes into a power save mode and when it first receives info on the RS232 port, the unit wakes up. However, the process of "waking up" can take several seconds.
To resolve this (according to Samsung), you can poll the status of the unit on a regular basis and it should work by preventing the "sleep mode".
Of course, we were not polling the unit, because it was on the 1 way RS232
IR port (during testing , it was moved to a real RS232 port to see if that made any difference).
The older Samsungs never used to do that.
I guess it's a feature...
I've got a new project coming up with Samsungs - I'll try the polling stuff and see if it is any better.
