Autopatch as Audio Switcher
RicardoSiqueira
I have used Autopatch as video switcher for years, but not as a Audio switcher. Does Autopatch provide the same functionality as the old/discountinued AS-16 with switching and audio control individualized per zone output (vol up, vol down, mute)? Does it provide 2 way communication, so we can implement feedback for bargraphs and matrix switching?
Also, what are you guys using for amplifiers? I am looking to have something to replace the also discountinued AMP8s for future jobs.
Any suggetions on the Autopatch and amplifiers???
Ricardo
Ricardo
Ricardo,
I have used an AutoPatch Modula switcher for audio control in several applications. It has proven to be a reliable switcher except for one power supply failure which apparently was an issue known to AutoPatch (they did not proactively contact customers - they waited for them to fail in the field which I found a little disappointing). They implement a decent RS232 protocol which is easy to work with and there are modules on the AMX web site for use (or for reference). In general, we have found the AutoPatch switcher to be reliable and easily controlled through AMX.
The switcher (at least the Modula we worked with) has volume up and down (although no support for ramping) but amazingly it did NOT support hardware MUTE and we had to implement muting in software. We spoke with them at CEDIA 2005 about mute and they indicated it was coming in a firmware update but we have not seen it. Some of the nice features you are used to with the AS16 such as levels of course do not exist and ramping has to be implemented in code.
To get volume control on the AutoPatch, you have to order the switch (at least it is true for the Modula) with their digital volume control card. There are versions of their audio switchers that do not provide volume control unless specifically requested and configured from the factory. They also have some switcher products such as Precis where volume control is standard.
I can not speak to the other AutoPatch audio switcher products since we have only used the Modula (32x32 application). I have also used large Extron matrix audio switchers and they are similar to the AutoPatch in terms of reliability, ease of protocol use, and features. Unless this has changed recently, the Extron 3200 and 6400 large matrices do not support volume control in the switch and I do not believe they have an option for volume control like the AutoPatch. We have successfully used AutoPatch and Extron matrix audio switchers in AMX environments using NXC-VOL4 volume control cards for volume control.
HTH,
Reese
They do have IP control options now that don't require anything special, never drop the connection, and uses the same RS232 protocol.
Kevin D.
I looked up the protocol, and it looks pretty straightforward, except that the first part of the string refers to a "level". What does this refer to when just switching?
Jeff Lockyear
Synergy Home Systems, Toronto
we use Extron & autopatch.
I steer away from using a switcher as a volume control.
I have never had great success with the ramping and feedback.
The AMX volume modules make life so much simpler, and the feedback
for a touch panel is accurate and consistant.
The level designation in Autopatch specifies the specific signals
that you want to switch (ie: audio, video, RGB, etc).
This allows breakaway switches.
For most applications, you would use a level zero to indicate
switching all audio & video.
Jeff Lockyear
More recently, I haver been working with the Vaux product. I like them so far, but haven't used them extensively enough to wholeheartedly endorse the product. I like that I can link a bunch of them together, have full volume, bass, treble, etc., and even built in audio presets. It's the most promising product I have used in this kind of application, and time will tell if they live up to the promise. I did have a bit of an issue with my first one with a firmware bug, and tech support jumped through hoops to resolve it; they had a buffer index set to CHAR that should have been INT (heh, I had to sympathize). But I got the distinct impression it was a one-man show over there. The same person answered for sales, support, everything. If he continues along the vein in which he started, he will definitely give Autopatch a run. It's a product to watch. The 3-4 switches I have running now on jobs are working flawlessly.
I was considering using two of their Lattis LE-400HD switches chained together to make an 8X8 HDTV component video and digital audio (S/PDIF) matrix switcher.
They list this caveat:
"Component video daisy-chain requires distrubution (sic) amp to split sources."
I think this means that you will only get 4 inputs max using these switches.
In that case, you must use their Lattis LE composite video switches to get more than 4 component sources.
Ricardo
The NXC-VOL4 does have 4 individual channels in & out.
For our commercial projects, we dont typically have more than
8 channels of audio including media and voice zones.
Obviously, in a residential scenario where there are many more zones,
this method can be quite costly.
My preference is to use a "bus" device for volume rather than an
RS232 device to eliminate constant string processing for feedback
to be used for bargraphs, etc.
I would not want a client to be discouraged with their system because
a bargraph does not keep up with the rest of the system as buttons are being pressed.
Autopatch will debut a new switch at NSCA next week that should be what everyone is looking for.
See the following link. http://www.autopatch.com/series_precis/lt_dsp/index.php
If price and/or rack space is not a problem, I highly recommend the AMX NXC-VOL4 as the most reliable and easy to program volume control solution.
My own rule is that the controller tells the equipment what to do, not the other way around.
I haven't used their component switcher, just composite. The composite switcher has a passthrough to daisy chain switchers; my reading of that caveat is that the component switcher has no passthrough, so if you need more than one switcher, you have to distribute the video signal to the multiple switchers. That's not uncommon with any manufacturer. But yes, you would wind up with a 4x8, not 8x8 ... however, the same would be true cascading composite switchers with a passthrough; you double the outputs, not the inputs. If you need more than that, you will have to go with a different switch. I generally use matrix switchers for multi-room distribution, and I have not done this with a component signal. If I need to distribute component, I put it on CAT 5 and do the switching locally.
The "standard video" board with a rated -3dB bandwidth at 50MHz passes 1080i component video perfectly.
The voltage regulators can run quite hot on the i/o boards but, as of yet, I have seen no problems related to them.
The protocol is painfully simple too.
