Transport Icons
Clingpeach
In the templates on the AMX web page there are icons that show up as text. ie up channel is shown as 0073. How do i put that into a tp4 panel that I am designing.
Thanks for any help
Thanks for any help
Select the AMX Bold font for the font of your button. Each letter for that font maps out to some sort of symbol. I don't know the complete mapping but the down arrow is "a", the record symbol is "p", the play button is "q", the up arrow is "s", and the AMX logo is "A."
You can also select AMX Icon or AMX Icon 2 for the font and you'll get some additional symbols.
I would assume there is a list of how these fonts map out but I've never found it.
Hope this helps.
Windows's own windings fonts have a lot of cool stuff too.
Kevin D.
Since I've never looked, and I'm sure you'd probably know where to look, I made one up really quick. Hope this help . . . and I hope I didn't forget anything.
The numeric keys in AMX Bold will only yield . . . numbers (what a coincidence!)
No problem everyone. I'm not sure if it's because I'm going blind or what, but that map is a little hard to read . . . SO I MADE IT BIGGER!!
Weird thing is . . . I'm not from Texas. LOL
Image is 1000 x 1000 px
If you don't know about the tool menu it is awesome, you can add shortcuts to other applications to TPD4 then then get added to the tools menu. You can do this by going to: View -> Customize then select the "tools" tab and add any application you wish. I also like to add the calculator and photoshop to the tools menu.
Also, Guifx.com has a great freebie set of fonts and a .pdf file with them all listed. There are some great icons. I use these alot...
http://www.guifx.com/product_info.php?cPath=23&products_id=200
BTW - Love your avatar.
they have a set of ttf fonts that can be used instead of the icons in a TP layout.
