Home AMX Technical Discussion
SMARTUPS rs232
I am trying to build a module to monitor/control a APC SmartUPS SC420 from an NI2000 rs232. Anybody been down this road yet?
Document Reference:
http://sibbald.com/apcupsd/3.8manual/upsbible.html
for example the string it says to send is "^N" or several different commands prefixed with ^
from hyperterminal the caret is not accepted, response=NA, however <ctrl>N ellicits the desired response
WHat would i use as an escape character so the the string "^N" is sent or do i have to send it as HEX, all the other commands are ASCII
also this is my first attempt at intelligent RS232 communication(query/response vs blindly sending strings)
what is the best way to parse the response? anyone have code snippets?
Thanks In advance
    Hi Paul,
    I don?t think ^N is meant to be sent as a 2 character string. I think it?s looking for SO (shift out) which is $0E in the ASCII chart. ^A = $01 and ^Z = $1A So?.
    SEND_STRING dvUPS, ?$0E? should turn the UPS on.
    HTH
  • YuriyYuriy Posts: 20
    It traces only some rresponses from APC UPS
    Code for parse of the response:
    DEFINE_CALL 'Parse Buffer' (char Buf[200])
      LOCAL_VAR char cJunk[20], cByte
      LOCAL_VAR integer nPos
      IF ((LENGTH_STRING(Buf)) > 1)
        cJunk = REMOVE_STRING (Buf,"$0A",1)
      ELSE
        cJunk = Buf
      SELECT
        ACTIVE (FIND_STRING(cJunk,'!',1)):
          OFF[vdvDEV,2]  // Line fail
        ACTIVE (FIND_STRING(cJunk,'$',1)):
          ON[vdvDEV,2]   // Line restory
        ACTIVE (FIND_STRING(cJunk,'%',1)):
          ON[vdvDEV,3] // Low battery
        ACTIVE (FIND_STRING(cJunk,'+',1)):
          OFF[vdvDEV,3] // Battery >= (25%)
        ACTIVE (FIND_STRING(cJunk,'#',1)):
          ON[vdvDEV,6] // Replace battery
        ACTIVE (FIND_STRING(cJunk,'SM',1)):
          ON[vdvDEV,10] // Smart mode
        ACTIVE (FIND_STRING(cJunk,'?',1)):
          ON[vdvDEV,11]  // Abnormal condition
          OFF[vdvDEV,10] // Smart mode
          CALL 'Add to Queue' ('Y')
          CANCEL_WAIT 'ABNORM'
          WAIT ABNORMAL_CONDITION_TIMEOUT 'ABNORM'
            OFF[vdvDEV,11]  // Abnormal condition
        ACTIVE (FIND_STRING(cJunk,'=',1)):
          OFF[vdvDEV,11] // Return from abnormal condition
      SELECT
        ACTIVE (cLastCmd = 'Q'):  // Status
          cJunk = "cJunk[1],cJunk[2]"
          cByte = HEXTOI(cJunk)
          [vdvDEV,1] = NOT(cByte = $00) // power
          [vdvDEV,2] = (cByte BAND $08) // on line
          [vdvDEV,3] = (cByte BAND $40) // battery low
          [vdvDEV,4] = (cByte BAND $10) // on battery
          [vdvDEV,5] = (cByte BAND $20) // overloaded output
          [vdvDEV,6] = (cByte BAND $80) // replace battery
        ACTIVE (cLastCmd = 'F'):  // Line frequency, Hz
          IF (LENGTH_STRING(cJunk) > 0)
            SEND_LEVEL vdvDEV, LINE_F_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'C'):  // Internal temperature
            SEND_LEVEL vdvDEV, TEMP_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'L'):  // Input line voltage
            SEND_LEVEL vdvDEV, LINE_U_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'M'):  // Maximum line voltage
            SEND_LEVEL vdvDEV, LINE_MAX_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'N'):  // Minimum line voltage
            SEND_LEVEL vdvDEV, LINE_MIN_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'O'):  // Output voltage
            SEND_LEVEL vdvDEV, OUTPUT_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'P'):  // Power load %
            SEND_LEVEL vdvDEV, LOAD_LEVEL, ATOF(cJunk)
        ACTIVE (cLastCmd = 'f'):  // Battery level
            SEND_LEVEL vdvDEV, BAT_LEVEL, ATOF(cJunk)
        ACTIVE (1):
          cLastCmd = ''
      CLEAR_BUFFER Buf
  • APC SMARTUPS-rs232
    Joe & Yuriy
    Thanks for the input, I worked out part of it own my own, but i will try your suggestions and let you know how it works out..
    Cheers,
    Good luck, Paul!
    About codes such as "^N" it is possible to look here:
    http://en.wikipedia.org/wiki/ASCII
  • APC SmartUPS SC 420 is now monitored/Controlled , MAX now gracefully shuts down
    Ok after alot of investigation, I have come up with this
    DATA_EVENT[dvSMARTUPS_RS232]
     COMMAND:
      // COMMAND event handler
     STRING:
      // STRING event handler
      SEND_STRING 0,"'string: SMARTUPS=',Data.Text"
      if (nLastCommandSent==1)
         IF (FIND_STRING(Data.Text,'50',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 50%'"
        IF (FIND_STRING(Data.Text,'49',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 49%'"
        IF (FIND_STRING(Data.Text,'48',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 48%'"
        IF (FIND_STRING(Data.Text,'47',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 47%'"
        IF (FIND_STRING(Data.Text,'46',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 46%'"
        IF (FIND_STRING(Data.Text,'45',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 45%'"
    	DO_PUSH(dvMAXMODERO,8)
    	SEND_STRING 0,"'Shutting Down MAX'"
    	wait 700
    	SEND_STRING dvSMARTUPS_RS232,"'S'"//soft shutdown ups after p(60 secs)
    	nLastCommandSent = 3 //o for cleared, 1 for BatteryQuery, 2 for SmartModeEnable,3 softpowerdown
        IF (FIND_STRING(Data.Text,'44',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 44%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'43',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 43%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'42',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 42%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'41',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 41%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'40',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 40%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'39',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 39%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'38',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 38%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'37',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 37%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'36',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 36%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'35',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 35%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'34',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 34%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'33',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 33%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'32',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 32%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'31',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 31%'"
    	wait 700
        IF (FIND_STRING(Data.Text,'30',1))
    	SEND_STRING 0,"'SMARTUPS Battery at 30%'"
    	wait 700
      IF (FIND_STRING(Data.Text,'!',1))
       nLowBatteryCounter++
       SEND_STRING 0,"'SMARTUPS Now IN BATTERY MODE'"
       SEND_STRING dvSMARTUPS_RS232,"'f'" //query battery level
       nLastCommandSent = 1 //o for cleared, 1 for BatteryQuery, 2 for SmartModeEnable,3 softpowerdown
      else IF (FIND_STRING(Data.Text,'$',1))
         SEND_STRING 0,"'SMARTUPS Back on A/C Line POWER'"
         SEND_COMMAND dvSMARTUPS_RS232,"'SET BAUD 2400,N,8,1'"
         wait 10
         SEND_STRING dvSMARTUPS_RS232,"'Y'" //turn on smart mode(feedback)
         nLastCommandSent = 2 //o for cleared, 1 for BatteryQuery, 2 for SmartModeEnable,3 softpowerdown
      else IF (FIND_STRING(Data.Text,'FF',1))
         SEND_STRING 0,"'Line POWER quality ok'"
      else IF (FIND_STRING(Data.Text,'%',1))
         SEND_STRING 0,"'SMARTUPS LOW BATTERY ALERT'"
         	//shut down max
    	//DO_PUSH(dvMAXMODERO,8)
    	//wait 700
    	//SEND_STRING dvSMARTUPS_RS232,"'S'"//soft shutdown ups after p(60 secs)
      else IF (FIND_STRING(Data.Text,'#',1))
         SEND_STRING 0,"'REPLACE BATTERY ALERT'"
      else IF (FIND_STRING(Data.Text,'+',1))
         SEND_STRING 0,"'SMARTUPS return to threshold From Low Battery'"
       else IF (FIND_STRING(Data.Text,'?',1))
         SEND_STRING 0,"'Abnormal condition'"
     ONLINE:
      // ONLINE event handler
         SEND_STRING 0,"'SMARTUPS Now Online @ 2400bps'"
         SEND_STRING 0,"'SMARTUPS Now in SMARTMODE- feedback enabled'"
     OFFLINE:
      // OFFLINE event handler
           SEND_STRING 0,"'SMARTUPS Now Offline'"
     ONERROR:
      // ONERROR event handler
           SEND_STRING 0,"'SMARTUPS some error occurred'"
    I know it is not extremely elegant code but it is functional..
    on low power it shuts down the Max and SoftSwitches the SmartUPS off untill the battery charges to 90%.(UPS return threshold set by 'e')
    Anybody has comments suggestions i would be happy to hear them.
    Cheers,
