DEVCHAN and GET_LAST
I'm familiar with using DEVCHAN arrays, and I can use GET_LAST with said array when there's only one touchpanel. If there's more than one TP, I run into problems with the value the GET_LAST gives me (I want it to be the same for each different panel).
DEVCHAN TP_BUTTON [] =
{TP1,10},{TP1,11},{TP1,12},
{TP2,15},{TP2,16},{TP2,17}
GET_LAST would return a 4 when TP2,15 is pushed, but in my code it would be much better to see a 1, like when TP1,10 is pushed. Do I need a separate DEVCHAN array per touchpanel? If I put all the panels in a DEV array first, I can't put that DEV in a DEVCHAN array, which would seem the best solution.
Make any sense?
Jeff Lockyear
Synergy Home Systems, Toronto
Make any sense?
Jeff Lockyear
Jeff,
Set up an array of devices and a separate array of channels.
Define_Device dvTP1 = 10001:1:0 dvTP2 = 10002:1:0 Define_Constant INTEGER nButtons[] = { 10, 11, 12 } Define_Variable DEV dv_TP[] = { dvTP1 dvTP2 } Volatile nCurrent_TP Volatile nCurrent_Button Define_Event Button_Event[dv_TP,nButtons] { Push: { nCurrent_TP = Get_Last(dv_TP) nCurrent_Button = Get_Last(nButtons) } }Jeff
