Displaying Variable Text on a Modero
Greetings,
How the heck do you get a variable text item appear on a button on a G4?
I am trying to use the (up arrow)TXT command in a similar fashion as in G3.
SEND_COMMAND dvMVP7500_TV_ADDRESS, "'^TXT-1,0',ITOA(nTV_TUNER_CHAN_ENTRY)"
dvMVP7500_TV_ADDRESS is the address port of the button and 1 is the address code of the button.
  • This works for me:
    SEND_COMMAND vdvTP,"'^TXT-906,1&2,',ITOA(cfgROOMNUM)"
    For button with address code 906
  • mushmush Posts: 288
    Greetings,
    G'day Turniptruck,
    You dropped a , from your string after the 0.
    Your string should look like this;
    SEND_COMMAND dvMVP7500_TV_ADDRESS, "'^TXT-1,0,',ITOA(nTV_TUNER_CHAN_ENTRY)"
    Cheers
