UPC20+ in europe?
Has anyone used the UPC20+ in europe with 220volts? According to its specs it should be possible but just to make sure... Usage should be for simple turning on/off power amps.
Bob.
Bob.
The internal relay contacts are rated to 250 volts IIRC, so you should be ok.
Just make sure that the internal voltage switch is set to 240 volts and not 110 as shipped unlike one of my installers who "forgot"!
