Dms Difficulties
hi guys, im having a problem..had to reprogram a house(NXI) that kept falling offline(too many acrobatics in code)
there is a sony 300 disc changer and it has to be controlled via DMS...
the specific application is pressing a "hundreds" button to increment/cycle the hundreds digit from 0 to 3, and so on for tens and ones.. after each increment it will(should but its not) update the dms display with the new digits.
im pulling my hair out cause i cant seem to make it work..
any suggestions, pointers? please
thanx in advance
char DMS8SelectedDisc[] = {0,0,0} //hundred,tens,ones
sinteger nDMS8hundreds = 0
sinteger nDMS8tens = 0
sinteger nDMS8ones = 0
define_event
button_event [vdvDMS8,DMS8_CDJUKE_HUNDREDS]
Push:
if (nDMS8hundreds == 3)
nDMS8hundreds = -1
nDMS8hundreds = nDMS8hundreds+1
DMS8SelectedDisc[1]= itoa(nDMS8hundreds)
//SEND_COMMAND vdvDMS8, "'@TXT',itoa(DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY),'Play #',',',DMS8SelectedDisc[0],DMS8SelectedDisc[1],DMS8SelectedDisc[2]"
SEND_COMMAND vdvDMS8, "'TEXT',itoa(DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY),'-Play #',DMS8SelectedDisc[1],DMS8SelectedDisc[2],DMS8SelectedDisc[3]"
//"'TEXT<vt channel>-<text>'"
send_string 0,itoa(nDMS8hundreds)
send_string 0,ITOA(DMS8SelectedDisc[])
WAIT 3
SEND_COMMAND vdvDMS8, 'PAGE-(CURRENT)'
//do not put any code after this line
(*cat5coaxrgb*)
thanx in advance
as it turns out i did not have my array declared properly...
char DMS8SelectedDisc[3][1] = {'0','0','0'} //hundred,tens,ones is how it should have been..
cheers
This is a follow up on my dms difficulties post from the other day...
for my cd juke interface i have the text updating on the DMS...
by using the klugy dms interface the user can press hundreds, tens or ones to increment the display with "play#_ _ _" then when they press that button if selected disc was 123 , I need to send ir pulses as follows,
"Disc-Del"//puts CDJUKE into #entry mode
"1"//hundreds digit
"2"//tens digit
"3"//ones digit
"Enter"//plays the selected
DEFINE_CONSTANT // {{NSX_DEFINE_CONSTANT IR_MEDIA_SONY_CD_cd1_play = 1 IR_MEDIA_SONY_CD_cd1_stop = 2 IR_MEDIA_SONY_CD_cd1_pause = 3 IR_MEDIA_SONY_CD_cd1_ams_1 = 4 IR_MEDIA_SONY_CD_cd1_ams_2 = 5 IR_MEDIA_SONY_CD_cd1_NEXT = 6 IR_MEDIA_SONY_CD_cd1_PREV = 7 IR_MEDIA_SONY_CD_cd1_power = 9 IR_MEDIA_SONY_CD_cd1_100 = 10 IR_MEDIA_SONY_CD_cd1_1 = 11///////// IR_MEDIA_SONY_CD_cd1_2_abc = 12////////// IR_MEDIA_SONY_CD_cd1_3_def = 13////////////// IR_MEDIA_SONY_CD_cd1_4_ghi = 14//////////////// IR_MEDIA_SONY_CD_cd1_5_jkl = 15////////////// IR_MEDIA_SONY_CD_cd1_6_mno = 16///////////////// IR_MEDIA_SONY_CD_cd1_7_qrs = 17///////////////// IR_MEDIA_SONY_CD_cd1_8_tuDN = 18///////////// IR_MEDIA_SONY_CD_cd1_9_wxy = 19///////////// IR_MEDIA_SONY_CD_cd1_10 = 20//////////////////// IR_MEDIA_SONY_CD_cd1_enter = 21///////////////// IR_MEDIA_SONY_CD_cd1_disc_skip_UP = 43 IR_MEDIA_SONY_CD_cd1_disc_skip_DN = 44 IR_MEDIA_SONY_CD_cd1_memo_scan = 45 IR_MEDIA_SONY_CD_cd1_highlight = 46 IR_MEDIA_SONY_CD_cd1_memo_input = 47 IR_MEDIA_SONY_CD_cd1_repeat = 48 IR_MEDIA_SONY_CD_cd1_check = 49 IR_MEDIA_SONY_CD_cd1_clear = 50 IR_MEDIA_SONY_CD_cd1_disc_del = 51/////////////////////////// IR_MEDIA_SONY_CD_cd1_group_space = 52 IR_MEDIA_SONY_CD_cd1_timetextcaps = 53 IR_MEDIA_SONY_CD_cd1_mega_xfade = 54 IR_MEDIA_SONY_CD_cd1_mega_no_delay = 55 IR_MEDIA_SONY_CD_cd1_mega_hit_list = 56 IR_MEDIA_SONY_CD_cd1_continue = 57 IR_MEDIA_SONY_CD_cd1_shuffle = 58 IR_MEDIA_SONY_CD_cd1_program = 59 // }}NSX_DEFINE_CONSTANT DMS8_CDJUKE_MEMPRESET_1 =111 DMS8_CDJUKE_MEMPRESET_2 =112 DMS8_CDJUKE_MEMPRESET_3 =113 DMS8_CDJUKE_MEMPRESET_4 =114 DMS8_CDJUKE_MEMPRESET_5 =115 DMS8_CDJUKE_HUNDREDS =116 DMS8_CDJUKE_TENS =117 DMS8_CDJUKE_ONES =118 DMS8_CDJUKE_PLAY_DISC_NUM=119 DMS8_CDJUKE_TRACK_NEXT =120 DMS8_CDJUKE_TRACK_PREV =121 DMS8_CDJUKE_DISC_NEXT =122 DMS8_CDJUKE_DISC_PREV =123 DMS8_CDJUKE_PLAY_PAUSE_TOGGLE=124 DMS8_CDJUKE_STOP =125 DMS8_CDJUKE_RANDOM =126 DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY = 130 //vt DEFINE_VARIABLE char DMS8SelectedDisc[3][1] = {'0','0','0'} //hundred,tens,ones sinteger nDMS8hundreds = 0 sinteger nDMS8tens = 0 sinteger nDMS8ones = 0 DEFINE_EVENT button_event [vdvDMS8,DMS8_CDJUKE_HUNDREDS] { Push: { if (nDMS8hundreds == 3) { nDMS8hundreds = -1 } nDMS8hundreds = nDMS8hundreds+1 DMS8SelectedDisc[1]= itoa(nDMS8hundreds) SEND_COMMAND vdvDMS8, "'TEXT',itoa(DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY),'-Play #',DMS8SelectedDisc[1],DMS8SelectedDisc[2],DMS8SelectedDisc[3]" //send_string 0,itoa(nDMS8hundreds) //send_string 0,ITOA(DMS8SelectedDisc[1] //send_string 0,ITOA(DMS8SelectedDisc[2] //send_string 0,ITOA(DMS8SelectedDisc[3] WAIT 3 SEND_COMMAND vdvDMS8, 'PAGE-(CURRENT)' } } button_event [vdvDMS8,DMS8_CDJUKE_TENS] { Push: { if (nDMS8tens == 10) { nDMS8tens = -1 } nDMS8tens = nDMS8tens+1 DMS8SelectedDisc[2]= itoa(nDMS8tens) //SEND_COMMAND vdvDMS8, "'@TXT',itoa(DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY),'Play #',',',DMS8SelectedDisc[0],DMS8SelectedDisc[1],DMS8SelectedDisc[2]" SEND_COMMAND vdvDMS8, "'TEXT',itoa(DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY),'-Play #',DMS8SelectedDisc[1],DMS8SelectedDisc[2],DMS8SelectedDisc[3]" //"'TEXT<vt channel>-<text>'" //send_string 0,itoa(nDMS8hundreds) //send_string 0,ITOA(DMS8SelectedDisc[1] //send_string 0,ITOA(DMS8SelectedDisc[2] //send_string 0,ITOA(DMS8SelectedDisc[3] WAIT 3 SEND_COMMAND vdvDMS8, 'PAGE-(CURRENT)' } } button_event [vdvDMS8,DMS8_CDJUKE_ONES] { Push: { if (nDMS8ones == 10) { nDMS8ones = -1 } nDMS8ones = nDMS8ones+1 DMS8SelectedDisc[3]= itoa(nDMS8ones) SEND_COMMAND vdvDMS8, "'TEXT',itoa(DMS8_CDJUKE_DISC_NUM_SELECT_DISPLAY),'-Play #',DMS8SelectedDisc[1],DMS8SelectedDisc[2],DMS8SelectedDisc[3]" //send_string 0,itoa(nDMS8hundreds) //send_string 0,ITOA(DMS8SelectedDisc[1] //send_string 0,ITOA(DMS8SelectedDisc[2] //send_string 0,ITOA(DMS8SelectedDisc[3] WAIT 3 SEND_COMMAND vdvDMS8, 'PAGE-(CURRENT)' } } /////////////// button_event [vdvDMS8,DMS8_CDJUKE_PLAY_DISC_NUM] { Push: { integer digit integer d; pulse[dvARCDJUKE,51]//disc button send_string 0,"'cd select number-h:',DMS8SelectedDisc[1][1]" send_string 0,"'cd select number-t:',DMS8SelectedDisc[2][1]" send_string 0,"'cd select number-o:',DMS8SelectedDisc[3][1]" digit=(DMS8SelectedDisc[1][1]) send_string 0,"'digit-h:',digit" switch(digit) { case '1': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_1] } case '2': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_2_abc] } case '3': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_3_def] } } digit=(DMS8SelectedDisc[2][1]) send_string 0,"'digit-t:',digit" switch(digit) { case '1': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_1] } case '2': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_2_abc] } case '3': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_3_def] } case '4': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_4_ghi] } case '5': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_5_jkl] } case '6': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_6_mno] } case '7': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_7_qrs] } case '8': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_8_tuDN] } case '9': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_9_wxy] } case '0': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_10] } } digit=(DMS8SelectedDisc[3][1]) send_string 0,"'digit-o:',digit" switch(digit) { case '1': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_1] } case '2': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_2_abc] } case '3': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_3_def] } case '4': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_4_ghi] } case '5': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_5_jkl] } case '6': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_6_mno] } case '7': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_7_qrs] } case '8': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_8_tuv] } case '9': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_9_wxy] } case '0': { pulse[dvARCDJUKE,IR_MEDIA_SONY_CD_cd1_10] } } wait 5 PULSE[dvARCDJUKE,21]//enter } }while watching my diagnostics and notifications i see the strings i am send to the master for "DMS8SelectedDisc[3][1]" and the "digit" currently being evaluated.
but for some reason(probably inexperience/sloppy code) it never fires
"1"//hundreds digit
"2"//tens digit
"3"//ones digit
any advice would be most appreciated..
cheers
I changed the type of array from char to integer...and fixed my single quotes..
end result, it works...
