Need some help MSP 8
I am having some issues with the followng code can someone give me some advise
Problems:
1. Feeback for button 8 isnt wokring
2. Having to hit button 5 for the power to actually cut off
3. Button 8 ( which is source 5 needs to be input # 7)
thanks
Problems:
PROGRAM_NAME='keypads'
(* System Type : NetLinx *)
(* REV HISTORY: *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
dvSwitcher = 5001:4:1 /// Ada Switcher * RS232
dvCd = 5001:9:1 /// Denon DCM 280 * IR
dvSatM = 5001:10:1 /// Direct TV D11
dvTuner1 = 5001:2:1 /// Z-Tuner : Zone 1 * RS232
dvTuner2 = 5001:3:1 /// Z-Tuner : Zone 2 * RS232
dviPort = 5001:1:1 ///
vdviPort = 33015:1:1 ///
dvMSP1 = 6001:1:1 /// Guest Room # 6
dvMSP2 = 6002:1:1 /// Guest Room # 7
dvMSP3 = 6003:1:1 /// Kitchen
dvMSP4 = 6004:1:1 /// Loggia
dvMSP5 = 6005:1:1 /// Pool
dvMSP6 = 6006:1:1 /// Guest Bedroom # 1
dvMSP7 = 6007:1:1 /// Guest Bedroom # 2
dvMSP8 = 6008:1:1 /// Guest Bedroom # 3
dvMSP9 = 6009:1:1 /// Guest Bedroom # 4
dvMSP10 = 6010:1:1 /// Her Master Bathroom
dvMSP11 = 6011:1:1 /// His Master Bathroom
dvMSP12 = 6012:1:1 /// Master Bedroom
dvMSP13 = 6013:1:1 /// Ocean Porch
vdvMSP1 = 33021:1:1
vdvMSP2 = 33022:1:1
vdvMSP3 = 33023:1:1
vdvMSP4 = 33024:1:1
vdvMSP5 = 33025:1:1
vdvMSP6 = 33026:1:1
vdvMSP7 = 33027:1:1
vdvMSP8 = 33028:1:1
vdvMSP9 = 33029:1:1
vdvMSP10 = 33030:1:1
vdvMSP11 = 33031:1:1
vdvMSP12 = 33032:1:1
vdvMSP13 = 33033:1:1
gdvTP = 7000:1:1
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
INTEGER nMSP_SC_Buttons[]=
1, /// Tuner
2, /// CD
3, /// Sat Music ( XM )
4, /// Request
8 /// Ipod
Integer nMSP_PWR_Button[]=
5 /// Power Off
INTEGER nMSP_VOL_Buttons[]=
6, /// Volume UP
7 /// Volume Down
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
CHAR strWhPwr[18]
INTEGER nKPButton
INTEGER nKPIndex
INTEGER nKPAddress
INTEGER nZnSc[18]
INTEGER nMute[18]
INTEGER nZoneSc
CHAR strDebug[255]
(* IPOD *)
VOLATILE INTEGER TP_BUTTONS[] = // Touchpanel button mapping array
// CHANNEL BUTTONS / Place Holder / Function
101, //01 Menu
102, //02 Select
103, //03 Play/Pause
104, //04 Offline/Online
105, //05 Previous<<
106, //06 Next>>
107, //07
108, //08
109, //09 List up 10
110, //10 List up 1
111, //11 List Down 1
112, //12 List Down 10
113, //13 List 1
114, //14 List 2
115, //15 List 3
116, //16 List 4
117, //17 List 5
118, //18 List 6
119, //19 List 7
120, //20 List 8
121, //21 List 9
122, //22 List 10
123, //23 Repeat
124, //24 Shuffle
125, //25 Playlist
126, //26 Now Playing
127, //27 List Level
130 //28 nothing
VOLATILE INTEGER TP_FIELDS[]= // VARIABLE TEXT BUTTONS
//Addres Codes / Place Holder / Function
100, //01 iPod Name
101, //02 List 01
102, //03 List 02
103, //04 List 03
104, //05 List 04
105, //06 List 05
106, //07 List 06
107, //08 List 07
108, //09 List 08
109, //10 List 09
110, //11 List 10
111, //12 Playing x of y
112, //13 Artist
113, //14 Album
114, //15 Track
115, //16 Time
116, //17 Repeat
117, //18 Shuffle
118, //19 Play Status
119, //20 List x of y
120 //21 Pathway
PERSISTENT INTEGER UI_LIST[] = {10,2,0} // See below: - not implemented in 1.0 Beta
(* All Key Pads *)
DEV dvKp[] = {vdvMSP1, vdvMSP2, vdvMSP3, vdvMSP4,
vdvMSP5, vdvMSP6, vdvMSP7, vdvMSP8,
vdvMSP9, vdvMSP10, vdvMSP11, vdvMSP12,
vdvMSP13}
(* Zone 1 *)
DEV dvKPZn1[] = {vdvMSP1, vdvMSP2, vdvMSP3, vdvMSP4,
vdvMSP9, vdvMSP13}
(* Zone 2 *)
DEV dvKPZn2[] = {vdvMSP10, vdvMSP11, vdvMSP12}
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
([vdvMSP1,1] .. [vdvMSP1,5])
([vdvMSP2,1] .. [vdvMSP2,5])
([vdvMSP3,1] .. [vdvMSP3,5])
([vdvMSP4,1] .. [vdvMSP4,5])
([vdvMSP5,1] .. [vdvMSP5,5])
([vdvMSP6,1] .. [vdvMSP6,5])
([vdvMSP7,1] .. [vdvMSP7,5])
([vdvMSP8,1] .. [vdvMSP8,5])
([vdvMSP9,1] .. [vdvMSP9,5])
([vdvMSP10,1] .. [vdvMSP10,5])
([vdvMSP1,11] .. [vdvMSP11,5])
([vdvMSP1,12] .. [vdvMSP12,5])
([vdvMSP1,13] .. [vdvMSP13,5])
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
DEFINE_CALL 'Zone On'
SWITCH(nZoneSc)
CASE 1:
SEND_STRING dvTuner1,"'W 1 1 1',13" /// Turn On Tuner Zone 1
PULSE[dvCD,1] /// Play On CD Player
/// Sat Music Power On
DO_PUSH(gdvTP,200) /// Request Zone 1 Connect
WAIT 5
DO_PUSH(gdvTP,25) /// Request Zone 1 Play
DO_PUSH(gdvTP,104) /// I-Pod Connect
WAIT 10
DO_PUSH(gdvTP,103)
SELECT
ACTIVE(nKPIndex < 10):
SEND_STRING dvSwitcher,"'`SVLR1R0',ITOA(nKPIndex),13"
SEND_STRING dvSwitcher,"'`SAD0',ITOA(nZnSc[nKPIndex]),'R0',ITOA(nKPIndex),13"
ACTIVE(nKPIndex > 9):
SEND_STRING dvSwitcher,"'`SVLR1R',ITOA(nKPIndex),13"
SEND_STRING dvSwitcher,"'`SAD0',ITOA(nZnSc[nKPIndex]),'R',ITOA(nKPIndex),13"
CASE 2:
SEND_STRING dvTuner2,"'W 1 1 1',13" /// Turn On Tuner Zone 2
/// Request Zone 2 Connect
/// Request Zone 2 Play
/// I-Pod Connect
SELECT
ON[nKPAddress,nZnSc[nKPIndex]]
strWhPwr[nKPIndex] = 'N'
strDebug = 'Zone On Call Is Running'
DEFINE_CALL 'Zone Source'
SWITCH(nZoneSc)
CASE 1:
SELECT
CASE 2:
SELECT
strDebug = 'Zone Source Call Is Running'
DEFINE_CALL 'Source Function'
SWITCH(nZoneSc)
CASE 1:
SWITCH(nKPButton)
CASE 1: /// Tuner Next Preset
SEND_STRING dvTuner1,"'W 1 3 3',13"
BREAK
CASE 2: /// CD Next Track
PULSE[dvCD,4]
BREAK
CASE 3: /// Sat Music Next Preset
BREAK
CASE 4: /// Request Next Track
DO_PUSH(gdvTP,32)
BREAK
CASE 5: /// IPOD Next Track
DO_PUSH(gdvTP,106)
BREAK
BREAK
CASE 2:
SWITCH(nKPButton)
SEND_STRING dvTuner2,"'W 1 3 3',13"
BREAK
PULSE[dvCD,4]
BREAK
BREAK
BREAK
BREAK
BREAK
OFF[nKPAddress,nZnSc[nKPIndex]]
WAIT 5
strDebug = 'Source Function Call Is Running'
DEFINE_CALL 'Zone Off'
IF(!(FIND_STRING(strWhPwr, 'N',1)))
SELECT
SEND_STRING dvSwitcher,"'`SRMOFR0',ITOA(nKPIndex),13"
SEND_STRING dvSwitcher,"'`SRMOFR',ITOA(nKPIndex),13"
SWITCH(nZoneSc)
CASE 1:
SEND_STRING dvTuner1,"'W 1 1 0',13"
BREAK
CASE 2:
SEND_STRING dvTuner2,"'W 1 1 0',13"
BREAK
PULSE[dvCD,2]
DO_PUSH(gdvTP,104)
strWhPwr[nKPIndex] = 'F'
ON[nKPAddress,5]
(* STARTUP CODE GOES BELOW *)
(* Power Status MSPs *)
strWhPwr = 'FFFFFFFFFFFFFFFFFF'
(* MSP Modules *)
DEFINE_MODULE 'MSPMod' modMSP1 (vdvMSP1, dvMSP1)
DEFINE_MODULE 'MSPMod' modMSP2 (vdvMSP2, dvMSP2)
DEFINE_MODULE 'MSPMod' modMSP3 (vdvMSP4, dvMSP3)
DEFINE_MODULE 'MSPMod' modMSP4 (vdvMSP4, dvMSP4)
DEFINE_MODULE 'MSPMod' modMSP5 (vdvMSP5, dvMSP5)
DEFINE_MODULE 'MSPMod' modMSP6 (vdvMSP6, dvMSP6)
DEFINE_MODULE 'MSPMod' modMSP7 (vdvMSP7, dvMSP7)
DEFINE_MODULE 'MSPMod' modMSP8 (vdvMSP8, dvMSP8)
DEFINE_MODULE 'MSPMod' modMSP9 (vdvMSP9, dvMSP9)
DEFINE_MODULE 'MSPMod' modMSP10 (vdvMSP10, dvMSP10)
DEFINE_MODULE 'MSPMod' modMSP11 (vdvMSP11, dvMSP11)
DEFINE_MODULE 'MSPMod' modMSP12 (vdvMSP12, dvMSP12)
DEFINE_MODULE 'MSPMod' modMSP13 (vdvMSP13, dvMSP13)
(* MISC *)
#INCLUDE 'Queue_and_Threshold_Sizes.axi'
(* Touch Panel *)
DEFINE_MODULE 'iPort_UI' IPORT_UI1(vdviPort, gdvTP, TP_BUTTONS, TP_FIELDS, UI_LIST)
DEFINE_MODULE 'iPort COMM' IPORT_MODULE(vdviPort, dviPort)
(* System Information Strings ******************************)
(* Use this section if there is a TP in the System! *)
SEND_COMMAND TP,"'!F',250,'1'"
SEND_COMMAND TP,"'TEXT250-',__NAME__"
SEND_COMMAND TP,"'!F',251,'1'"
SEND_COMMAND TP,"'TEXT251-',__FILE__,', ',S_DATE,', ',S_TIME"
SEND_COMMAND TP,"'!F',252,'1'"
SEND_COMMAND TP,"'TEXT252-',__VERSION__"
SEND_COMMAND TP,"'!F',253,'1'"
(* Must fill this (Master Ver) *)
SEND_COMMAND TP,'TEXT253-'
SEND_COMMAND TP,"'!F',254,'1'"
(* Must fill this (Panel File) *)
SEND_COMMAND TP,'TEXT254-'
SEND_COMMAND TP,"'!F',255,'1'"
(* Must fill this (Dealer Info) *)
SEND_COMMAND TP,'TEXT255-'
(* THE EVENTS GO BELOW *)
BUTTON_EVENT [dvKPZn1,nMSP_SC_Buttons]
nZoneSc = 1
BUTTON_EVENT [dvKPZn2,nMSP_SC_Buttons]
nZoneSc = 2
BUTTON_EVENT [dvKP,nMSP_SC_Buttons]
nKPButton = Get_Last(nMSP_SC_Buttons)
nKPIndex = Get_Last(dvKP)
nKPAddress = (nKPIndex + 33020)
SELECT
ACTIVE(!(strWhPwr[nKPIndex] = 'N') AND nKPButton < 6):
nZnSc[nKPIndex] = nKPButton
CALL 'Zone On'
ACTIVE(strWhPwr[nKPIndex] = 'N' AND nKPButton < 6 AND nKPButton = nZnSc[nKPIndex]):
ACTIVE(strWhPwr[nKPIndex] = 'N' AND nKPButton < 6 AND !(nKPButton = nZnSc[nKPIndex])):
CALL 'Zone Source'
HOLD[20]:
SWITCH(nZoneSc)
CASE 1:
SWITCH(nKPButton)
CASE 1: /// Tuner Previous Preset
SEND_STRING dvTuner1,"'W 1 3 4',13"
BREAK
CASE 2: /// CD Next Disc
PULSE[dvCD,50]
BREAK
CASE 3: /// Sat Music Previous Preset
BREAK
CASE 4: /// Request Next Album
BREAK
CASE 5: /// IPod Previous Track
IF(nZnSc = 5)
nZnSc[nKPIndex] = 7
DO_PUSH(gdvTP,105)
BREAK
CASE 2:
SWITCH(nKPButton)
SEND_STRING dvTuner2,"'W 1 3 4',13"
BREAK
PULSE[dvCD,50]
BREAK
BREAK
BREAK
CASE 5: /// IPod
IF(nZnSc = 5)
nZnSc[nKPIndex] = 7
DO_PUSH(gdvTP,105)
BREAK
BUTTON_EVENT[dvKP,nMSP_VOL_Buttons]
nKPButton = Get_Last(nMSP_VOL_Buttons)
SWITCH(nZoneSC)
CASE 1:
SWITCH(nKPButton)
CASE 1:
SELECT
SEND_STRING dvSwitcher,"'`SVLUPR0',ITOA(nKPIndex),13"
SEND_STRING dvSwitcher,"'`SVLUPR',ITOA(nKPIndex),13"
PULSE[nKPAddress,6]
CASE 2:
SELECT
SEND_STRING dvSwitcher,"'`SVLDNR0',ITOA(nKPIndex),13"
SEND_STRING dvSwitcher,"'`SVLDNR',ITOA(nKPIndex),13"
PULSE[nKPAddress,7]
CASE 2:
SWITCH(nKPButton)
CASE 1:
SELECT
PULSE[nKPAddress,6]
CASE 2:
SELECT
PULSE[nKPAddress,7]
HOLD[2,REPEAT]:
SWITCH(nZoneSC)
CASE 1:
SWITCH(nKPButton)
CASE 1:
SELECT
PULSE[nKPAddress,6]
CASE 2:
SELECT
PULSE[nKPAddress,7]
CASE 2:
SWITCH(nKPButton)
CASE 1:
SELECT
PULSE[nKPAddress,6]
CASE 2:
SELECT
PULSE[nKPAddress,7]
BUTTON_EVENT[dvKp,5]
CALL 'Zone Off'
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
[vdvMSP1,5] = (strWhPwr[1] = 'F')
[vdvMSP2,5] = (strWhPwr[2] = 'F')
[vdvMSP3,5] = (strWhPwr[3] = 'F')
[vdvMSP4,5] = (strWhPwr[4] = 'F')
[vdvMSP5,5] = (strWhPwr[5] = 'F')
[vdvMSP6,5] = (strWhPwr[6] = 'F')
[vdvMSP7,5] = (strWhPwr[7] = 'F')
[vdvMSP8,5] = (strWhPwr[8] = 'F')
[vdvMSP9,5] = (strWhPwr[9] = 'F')
[vdvMSP10,5] = (strWhPwr[10] = 'F')
[vdvMSP11,5] = (strWhPwr[11] = 'F')
[vdvMSP12,5] = (strWhPwr[12] = 'F')
[vdvMSP13,5] = (strWhPwr[13] = 'F')
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
thanks
