Mutually Exclusive With Arrays
I have a button array and a device array.
In this particular case , these buttons are for navigation between rooms.
Obviously I cannot have 2 rooms selected at once on a panel.
My statement will read something like this...
dvTP_1=128:1:1
DEFINE_CONSTANT
INTEGER nBtnArray_RoomNav[]={3001,3002} //Array For Navigation Button Numbers
DEV dvAllTP[]={dvTP_1} //Array For Touchpanels
BUTTON_EVENT [dvAllTP,nBtnArray_RoomNav]
Push:
Do Whatever
How do I define the arrays' buttons as mutually exclusive?
Rolo
dvTP_1=128:1:1
DEFINE_CONSTANT
Push:
Do Whatever
Rolo
BUTTON_EVENT [dvAllTP,nBtnArray_RoomNav] { Push: { STACK_VAR INTEGER nIND STACK_VAR INTEGER nBTN nIND = GET_LAST(dvAllTP) nBTN = GET_LAST(nBtnArray_RoomNav) ON[dvAllTP[nIND],nBtnArray_RoomNav[nBTN]] } }And then set up your MUTUALLY_EXCLUSIVE. But I personally wouldn't even go that route. I would set up a variable that kept track of which room the panel was on, then set the feedback down in DEFINE_PROGRAM. You could easily do something like this:DEFINE_VARIABLE nCUR_ROOM[x] // x = THE NUMBER OF TOUCH PANELS DEFINE_EVENT BUTTON_EVENT [dvAllTP,nBtnArray_RoomNav] { Push: { STACK_VAR INTEGER nIND STACK_VAR INTEGER nBTN nIND = GET_LAST(dvAllTP) nBTN = GET_LAST(nBtnArray_RoomNav) nCUR_ROOM[nIND] = nBTN // DO REST OF BUTTON PUSH STUFF } } DEFINE_PROGRAM [dvAllTP[1],nBtnArray_RoomNav[1]] = (nCUR_ROOM = 1) [dvAllTP[1],nBtnArray_RoomNav[2]] = (nCUR_ROOM = 2)This way, if you ever need to know which room a panel is controlling, you can run conditionals / evaluations, etc. on this information.
BUTTON_EVENT[dvaTPs,nNavBtns] // Navigation { PUSH: { STACK_VAR INTEGER nPnlIdx ; STACK_VAR INTEGER nBtnIdx ; STACK_VAR INTEGER nLoop ; nPnlIdx = GET_LAST( dvaTPs ) nBtnIdx = GET_LAST( nNavBtns ) FOR(nLoop = 1; nLoop <= LENGTH_STRING( nNavBtns ); nLoop++) OFF[dvaTPs[nPnlIdx],nNavBtns[nLoop]] ON[dvaTPs[nPnlIdx],nNavBtns[nBtnIdx]] } }But like James said it's nice to have a var tracking your selections because the buttons will turn off if the panel goes offline (which is actually a benefit in some situations).
