i!-PCLinkXtra
Has anyone tested .NET compatibility of i!-PCLinkXtra.ocx?
  • Charles LawCharles Law Posts: 72
    I found that i!-PCLinkXtra.ocx only works with ASP.NET. If you want C# or VB.NET, you will need to use i!-PCLinkXtra.dll
    Charles
    Wow. Joel on an AMX board. Wait until I report back to the Cre$tron crew. :)
  • joelwjoelw Posts: 175
    Charles
    Hmm I'll check it out. I've used i!-PCLinkXtra.ocx no problem in VB6.
    Example Application
    Attached is very basic program built in VB.NET. It provides ability to connect to a Netlinx processor from a PC running .NET 2.0.
    It requires the following to be present and installed or app will fail:
    i!-PCLinkXtra.ocx
    i!-PCLinkXtra.dll
    Once you connect to your Netlinx processor, Command, Serial, Channel, and State Change info is displayed in the status bar.
    If anyone wants similar example without .NET dependency let me know.
  • LegacyUserLegacyUser Posts: 0
    looks interesting. i have downloaded it. but where is i!-PCLinkXtra.
    i've searched AMX and yahoo .. please tell me more, thanks.
    Hi Richard,
    I posted how to find it here: http://amxforums.com/showthread.php?t=1544
