Home AMX Design Tools
Popup Page Properties
In the General tab of Popup Page Properties,
there is a setting labeled "reset pos on show".
Does anyone know specifically what this setting does?
Thanks.
  • If you make your popup dragable....it will reset the pop-up to its original location when it shows again.
    **Did you know you can drag your popus around the panel???**
    Channel Port: 0
    Channel Code: Panel Setup: Popup Drag
    Well - Kenny beat me to it, so read his post. :)
