Discretes for Sagem and Bang&Olufsen
Hi there,
i'am urgently looking for discrete power on/off ir codes for Sagem and B&O devices. the model is not important, because i hope i can calculate the specific code for my devices.
Can anyone help?
Can anyone help?
There is no Power toggle command for B&O, transmit the source you want and the system will turn on to that source or change source if already on. Press the standby and the system will turn off. If you press and hold the Standby the Beo4 remote will transmit a diffrent command and the whole house will turn off.
Hope this helps.
