Aprilaire Thermostats (Viewstat)
Has anyone recently used the Duet module to control a larger number of these? I have 12 thermostats currently connect and I am having issues. I am just wondering if there are any quirks with the module I need to be aware of before diving head first into comm bus trouble shooting.
UPDATE:
It appears to be comm problems. Of course the only unit with comm problems is the one I was trying (happens to be the closest to the dist panel). It also didn't help that there were a few stats that weren't set.... Why do I even bother asking someone else to set these up initially???
UPDATE:
RX - to RX -
RX+ to RX+
TX+ to TX+
TX- to TX-
Another suggestion is to wire only one thermostat to the Netlinx Master and make your code control it and then expand to control the others.
I was also having problems with the module's UI. What brought light to my control was the Design Xpress way of handling the HVAC. The Design Xpress code is very efficient and can expand to as many TPs you may have, with proper feedback handling and updates. I studied the Design XPress code, trimed the stuff that I didn't need and it works good for my 9 VSTs system. The Design Xpress code can also handle either Serial or ICSNet versions from the same UI. The problem that I found with the ICSNet and Duet Modules was that they are both designed to control many zones from one panel and you have to customize a lot the UI to control the VSTs without conflicts from multiple Tps. Both UIs also process a lot more info/data that you may need. Take a look at the Design Xpress code.
Ricardo
I'll let you know if I figure anything else out.
All works fine.
I agree 100%, use the disty panel.
Homerun all the stats.
This seems like a good a place as any to post a Viewstat question. I just did 2 implementations using the viewstat netlink module. The sample implementation was way, way more than I needed, so I studied it for awhile and trimmed it way back. For the first job, I put it together as as UI module (2 stats, 2 wireless TPs), for the second job (3 stats,3 wireles s TPs), I redid it using dev and button arrays and kept it in the Main. In both cases I get a little quirky behaviour. Often, on reboot, I get things like --F for temp or --% for humidity. These eventually resolve to usable numbers, but the 'F' usually goes away. I got around this by putting in a timeline, every minute I send out queries at 20, 23, 26, etc seconds to update the buttons (one button per time period) that misbehave. Seems to work, but I can't help feeling something is slightly broken somewhere. Anybody else have symptoms like this?
I should mention this is my first post and my AMX/Netlink/VBulletin experience level is very modest. So be gentle.
Bob Moyle
Audio Design Innovations
Installer, Programmer 1
I used to do the code like you and always had a little glitch here and there. Then, I decided to take a look at the code that Design Xpress generates and it simplified a lot the way I control the VSTATS. The Design Xpress code works with ICSNet and Serial communications and you can use it as an include file in any project. The code even handles feedback per panel efficiently. You'll need to customize the code a little for your needs, but I have 11 Modero TPs and 9 vstats running on it. I strongly recommend you taking a look at the Design Xpress code.
Ricardo
San Diego
